July 17, 200818 yr Author comment_261669 i was using up what i had left over, i wrapped up the starter motor with it. looks fair ghetto in full view around the air filter, but will probably change it one day. Edited July 17, 200818 yr by Jono Report
February 26, 200917 yr Author comment_322755 sadly, no. last i heard he was having to get it passed emissions testing in SA which meant adding some emissions gear to the setup. Report
February 26, 200917 yr comment_322758 Sounds like somebody doesn't know the right people.... :lolcry: Report
February 26, 200917 yr Author comment_322768 perhaps you could shoot him a PM Mr Redward, his name on here is Madaz4. seems such a shame as it was 100% legal in NSW which made it all the more fun to drive. Report
February 26, 200917 yr comment_322774 Unfortunately I can't help him in SA. Qld I could help with. I agree, but this is what NCOP is supposed to help with. Oh wait, NSW aren't signing up to it.... :lolcry: Edited February 26, 200917 yr by Redwarf Report
October 16, 200917 yr comment_382521 Picture of the final position of motor. Can other people who have done this conversion please put up pics in this thread to compare position of the motor? bit late.. but this is how i mounted mine in '99. before i knew much about driveline geometry. wasn't much info on this sort of thing then. wanted it as low as it could go and as rear as it could go for best weight balance without any chassis cutting. one thing i did not realise was driveshaft yolk angles were on the piss. so 6mths of driving and driveshaft uni's were getting a bit noisey at 180km/h. will redo it eventually. used the std gearbox crossmember position and redrill the rubber mount holes. had like 5mm clearance on the drag links (steering) at full lock both ways. plenty room on the sway bar (i have the later type which is better suited). i shortened l/h crossmember mount for room to get oil filter on. factory exhaust manif still fit fine. had to swap from twin brake master to a single for inlet clearance. (this will change when i get round to it). just a comparison anyways http://toycrazy.net/mark/1stStage.htm good to see some info online about mounting these things. :jamie: no more news on this ride? Edited October 16, 200917 yr by AE25 Report
April 11, 201115 yr comment_516420 Mate u gotta help me I Doing the same thing but for the life of me I can't find the engine mounts Report
April 11, 201115 yr comment_516485 Think they'll have to be custom jobbies mate...next to no chance of finding good mounts already made up. Any fabrication shop should be able to hook you up, expect to pay upwards of $1000 for good quality engine & gearbox mounts. If you look at my thread, my mounts cost me 1600 (Poly tubular engine mounts & tube gearbox xmember using supra mount), through Shanon @ Simply Maz (Sydney). Hope that helps Report
