just bought new set of mains and conrad bearing... but i was not able to crank it by hand after installing it in my 3k.. is it normal since it is new and no oil yet? just wondering how to adjust valve clearance if crank feels locked up and can't rotate...anyway it is all standard size.. thanks!..cheers!.
If you can't rotate it by hand, it's waaayyyyyy too tight!!! Thats with out the spark plugs in it right?
You'll have to pull it down and go stupid cleaning everything. Might just be some crap caught behind the shells.
I had the same thing initially as I just put stock size mains and bigends back on the crank. I never had it dipped to clean the tar off and the new bearings were a fraction of a mm wider, which was enough to grip the tar at the edge of the crank journal. It looked like nothing, but when it had been cleaned it was fine.
the main caps have numbers 1 to 5 and arrows on it so i think its just fine.. conrad caps have numbers 1 and 3 only... i don't know if my daughter shuffle it in the garage.. any idea on that?... just new on this... what you mean tang facing tang? thanks!!!
ok... I'm going to take some pic tommorow... I'm not confident that my conrad caps are in right position... standard size should be rotated by hand right? unless the store give me undersize...
thanks for all the suggestions... it works good now.. here's what happened.
remove all caps except mains - able to rotate
install piston #1 caps - able to rotate
install piston #2 caps - unable to rotate
remove caps on piston #2 and install # 3 - able to rotate
install caps on piston # 4 - unable to rotate
swap caps on 2 and 4 - able to rotate when all tightened---- cheers!
my daughter might swap it..
is that stamp factory stadard? i saw that firts caps don't have, the 2nd one has 1 dot, the 3rd has two and the fourth piston has 3... it looks that it was hammered by nail or something...
Didnt come with factory stamps ,but the general rule is mark 1 to 4 both cap and rod with a centre punch on camshaft side.
Maybe they marked 1to 3 and didnt mark the 4th??
Should always mark them as you pull them out ,that way you can be sure.
rob
