Hi all,
So trying to put my front end back together, any tricks to get the sway bar bushes to work? nut don't fit, should i pull out the heat gun?
Car is an AE71 with Pedders bushes, stock swaybar, ke55 LCA
They're a universal fit item. I would get some that are a better fit.
If you want to screw around, you could cut them down, or make your own swaybar links with threaded rod.
