Hi all
been lurking on here for a little while and thought i should post up my project
sold my daily 300+kw jzx100 and bought a more sensible daily , but found it wasnt enough to satisfy me so a project car was
decided .
as i wanted something light after the jzx100(only downfall they are a bit heavy)
was looking at ra/ta celica's(so i could stay with a 1jz) , then moved to old corollas initailly ke20's ect when i found this ke30 and bought it.
it was recently resprayed but has a few areas that need re doing but no rust that i can find
few pics at home
and few pics form previous owners that i was able to get hold of
apparently it used to have a v8 in it so tunnel has been made larger which left me with bulk room for engine/gearbox combo's
looked at different conversions for a while then decided s14 sr20det was the best choice to still be able to register with most potential
reasoning= newish engine. factory rwd 2lt turbo with lots of cheap aftermarket support
what you guys think?
will update what i've don't so far and where i'm up to soon
cheers,Matt
Edited by indelible
so then i bought a s14 sr20det and rb20 gearbox + sr20 bellhousing
engine arrived
then pulled old engine out and gave it away for free as it had a bottom end knock i was told(never bothered to start it as had flat battery too)
then cleaned up the sr20 and found it had 2 warrenty seals one on block and one on head so looks to be rebuilt at some point
then pulled apart the rb box and fitted the sr bellhousing and cleaned it up and painted it
next i dummy fit the engine and decided it was best to cut the engine mounts off the crossmember and start from
scratch as they looked to have been messed with and didnt trst them with silicone everwhere
ended up doing similar to other rollaclub members ke sr20 engine mounts
once i hade these plates tacked in i put motor in and got it to sit where i wanted +dummied up some mounts out of cardboardas
then had them plasma cut
then bent them up at work
and tacked them into position using some vibratechnics rubber mounts for an escort it think as they were nice and thin
sump clearance
and shifter hole (only so large from dodgey hole in it before)
engine in position
then started making gearbox crossmember out of 50x25x3 rhs
next i wanted to make my own turbo manifold for a gt3076r spec turbo i had sitting around gathering dust form my jzx100
so went and visited the guy who had previously made my turbo manifolds for me and got some bits to start my own
out of 32nb shc40 mild steel steam pipe
then began making it once i had worked out the position i wanted the turbo to sit and made a jig
runner by runner getting there
all 4 runners done
then cut all runners of to make wastegate outlet
then got it professionally tig welded up for a better appearance and piece of mind reliability wise
now its getting ceramic coated
and thats where i'm up to currently
Thats a tidy little 2 door. Carlos (BUZ440) on here had one with an SR20 and it was pretty (a lot) nuts.
thanks mate , this should be pretty nuts too haha
thanks guys ,
doogs the gate pipe will be made with v band flanges to plumb back or go atmo easily.
don't think the engine mounts will bend/break any time soon as they are 5mm steel hahahaha
thanks guys ,
Awesome, I love the idea of a screamer on the street but I don't think the boys in blue share that opinion! :fuzz:
