Indelible's 74 Ke30 Sr20Det Coupe
Looks great, loving the progress so far.
  • Replies 35
  • Views 137.1k
  • just got my turbo manifold back from ceramic coating :D
thanks mate
few pics from today
Edited by indelible
  • 10 months later...
did a little bit of work on the rolla today made new trans tunnel cover , still need to weld it on but much better then a big hole ohmy.png
so went from this
to this
Edited by indelible
That manifold is a work of art !!!
Well played Sir !!
Cheers, Scott
Well played Sir !!
Cheers, Scott
thanks , spent alot of time designing/fabricating it to be perfect , pretty happy with how it turned out
welded up trans tunnel cover today then etch primed it,pleased with how it turned out.
Will use some tar sealer inside tunnel when gearbox/ engine is out
Edited by indelible
  • 2 months later...
for last few weeks been working on making seat rails for my s5 fc3s seats
finished and painted
while paint was drying started installing new moulded carpet (which sucks to do sooo bad)
rail installed back in car with new carpet
was dark this evening by the time i finished trimming the carpet down and intsalled the seat so pics will have to come next weekend
made new door cards , from masonite , foam and black marine vinyl
new carpet with new door trims and rx7 seat installed
vinyl painted the rear seats black + made new rear side interior trim panels same as front door cards
interior is now looking much nicer
decided to install radiator and fmic
so got a alloy radiator for a nissan s14
then made up a steel brace for the front cross member as stock ones requires some trimming for the radiator
close up of welds
radiator dummy fitted to check fitment/bonnet clearance with brace installed
still need to make up the mounting brackets will make them next few weeks and start installing fmic
but etch primed it all to stop rust/corrosion
made the brackets and got radiator mounted today , will start on mounting intercooler next rain free day off as tomorrow's forecast isnt looking good
lower bracket
upper bracket
since the rain held off , i had a pretty successful weekend working on the rolla
got the front mount intercooler done
front section cut for fmic and painted black
lower radiator and intercooler mounts installed
radiator installed
radiator + intercooler installed
piping routing
lower valance installed with 0 cutting
clearances
grill +bumper installed with 0 cutting
few random shots
