April 13, 201313 yr Author comment_653062 thanks mate few pics from today Edited April 13, 201313 yr by indelible Report
March 8, 201412 yr Author comment_679049 did a little bit of work on the rolla today made new trans tunnel cover , still need to weld it on but much better then a big hole so went from this to this Edited March 8, 201412 yr by indelible Report
March 9, 201412 yr comment_679138 That manifold is a work of art !!! Well played Sir !! Cheers, Scott Report
March 13, 201412 yr Author comment_679361 That manifold is a work of art !!! Well played Sir !! Cheers, Scott thanks , spent alot of time designing/fabricating it to be perfect , pretty happy with how it turned out Report
March 30, 201412 yr Author comment_680267 welded up trans tunnel cover today then etch primed it,pleased with how it turned out. Will use some tar sealer inside tunnel when gearbox/ engine is out Edited March 30, 201412 yr by indelible Report
June 29, 201412 yr Author comment_684824 for last few weeks been working on making seat rails for my s5 fc3s seats finished and painted while paint was drying started installing new moulded carpet (which sucks to do sooo bad) rail installed back in car with new carpet was dark this evening by the time i finished trimming the carpet down and intsalled the seat so pics will have to come next weekend Report
July 13, 201412 yr Author comment_685489 made new door cards , from masonite , foam and black marine vinyl new carpet with new door trims and rx7 seat installed Report
July 20, 201412 yr Author comment_685817 vinyl painted the rear seats black + made new rear side interior trim panels same as front door cards interior is now looking much nicer Report
July 26, 201412 yr Author comment_686088 car is now regrettably for sale http://www.rollaclub.com/board/topic/70068-ke30-2door-with-sr20det-engine/ Report
August 10, 201412 yr Author comment_686826 decided to install radiator and fmic so got a alloy radiator for a nissan s14 then made up a steel brace for the front cross member as stock ones requires some trimming for the radiator close up of welds radiator dummy fitted to check fitment/bonnet clearance with brace installed still need to make up the mounting brackets will make them next few weeks and start installing fmic but etch primed it all to stop rust/corrosion Report
August 16, 201412 yr Author comment_687104 made the brackets and got radiator mounted today , will start on mounting intercooler next rain free day off as tomorrow's forecast isnt looking good lower bracket upper bracket Report
August 24, 201412 yr Author comment_687431 since the rain held off , i had a pretty successful weekend working on the rolla got the front mount intercooler done front section cut for fmic and painted black lower radiator and intercooler mounts installed radiator installed radiator + intercooler installed piping routing lower valance installed with 0 cutting clearances grill +bumper installed with 0 cutting few random shots Report
