4agze Ke70 Help?
Hi,
I'm new hear and need some help with my conversion. I've got a hydraulic clutch from an AE71, but need some help with the KE70's pedal box. What do i do with it. Modify it, or can i swap the AE71 pedal box over??? :sad:
Also, with the fuel setup. What have people done. I've got a surge tank, Vl turbo high pressure pump and a pre pump. Where is the best place to mount this gear? Boot? Under car? Engine bay? Also how have people set it up.
Thanks
  • Replies 42
  • Views 38.3k
Probably easiest to swap the AE71 box over. Should bolt in, if not shouldn't take much to bolt it in.
Fuel setup, best to get an in-tank, but they aren't common. With a KE70 (sedan) you can put the surge tank in the boot, or under the car, or in the engine bay, but talk to your engineer before mounting it. Some engineers have preference for where it should be.
Thanks guys.
I'll keep you posted on the conversion. :D
Umm... You need to get an in-tank pump to suit your tank. For one thing, it needs to sit at the bottom of your tank, and it needs to be secured somehow. If you're lucky you might be able to adapt something from a different car, but that's up to you to experiment.
  • 4 weeks later...
VL's have both a low volume internal pump and a high pressure external pump
also you hear a lot of different stories about whether or not VL turbo and non turbo pumps flow the same.
the part numbers from bosch for both the turbo and non turbo vl fuel pumps are the same, but these are part numbers for replacement pumps. The part numbers on the original factory pumps are different. So yes a brand new VL non turbo pump will flow just as much as a brand new turbo one (some places even charge more if you ask for a turbo one even though it's exactly the same part) but if you get the part second hand from a wreckers the turbo and non turbo pumps are different
so the factory turbo ones flow more than the factory na ones but new ones are the same???
check out the ' camira ' efi pump
same thing I believe but cheaper
As I said I would keep you guys updated. don't know where else to put it but here it is finished. Yay, heeps stoked aswell. :) Still needs a good tune though.
Car:
1984 KE70E Corolla CS
Engine:
AE101 4AGZE
Engines Accesories:
4-1 TRD style extractors into 2.5in exhaust
Pod Filter (soon to be K&N)
Microtech MTX-8
1G-GTE FMIC
VL fuel pump
Surge tank
Drivetrain:
Spritner T50
Heavy Duty CLutch
AE71 Tailshaft
Stock Diff
Brakes:
Starion Master Cylinder
[Front]
Hilux 4 pot caliers, Brembo 605 discs, XT130 struts
[Rear]
Stock Drums
Suspension:
Whiteline Adjustable panhard rod
Wheels:
15x6 Performance Superlites
195x50x15in Kumo's
Bodywork:
Debaged and Destriped.
Interior:
Autometer Gauges:
Carbon Fibre: Boost, Volts, A/F Ratio
Autogage 3in Tacho
Microtech Hand COntroller
Also some pics.
http://www.pbase.com/image/31372609
http://www.pbase.com/image/31372620
http://www.pbase.com/image/31372649
http://www.pbase.com/image/31372659
http://www.pbase.com/image/31372699
http://www.pbase.com/image/31372890
Enjoy :dance:
That's pretty cool. You found a Starion master cylinder??? Wow! I was looking for one of them ages ago and then gave up, ended up getting a Pajero unit instead.
Nice rims, but don't really think they suit the car... Apart from that, looking good :)
Thanks guys. I think once I lower it a bit the wheels should compliment the car more. Its still at stock height.
Finally got it dyno tuned, and here is the result.
http://www.pbase.com/chrizer/image/31726898
102.3kw at the wheels.
Very happy with it. As you can see on the graph it held boost all the way to redline. It pulls very hard and I am so happy with it. Finally all the hard work and effort has payed off. :P
