October 22, 201313 yr comment_669948 After much deliberation i have decided to keep my 4k as it only has 100,000 on the clock, was thinking about a Gilmer drive but not at 600 a pop what alternatives are there to the Gilmer drives ? Report
October 22, 201313 yr comment_669949 Holden, ford or chev 2nd hand one and modify pulleys to suit. Seen them go for 100-150 Report
October 22, 201313 yr comment_669952 Yeah, there is no 'bolt on' alternative. Theyre pretty much 100% wank factor on a 4k anyway. Report
October 22, 201313 yr comment_669956 dab of valvegrinding paste on alternator bearing " WHIRRRRR" lol Report
October 22, 201313 yr comment_669959 Grab some old timing belt pulleys for any accessory driven items maybe need to buy a crank pulley though. Report
October 23, 201313 yr comment_670031 dab of valvegrinding paste on alternator bearing " WHIRRRRR" lol bahahhaha :thumbsup: Report
November 5, 201312 yr comment_671024 I reckon wedge belts and pulleys would probably be the best and most straightforward option... Report
November 5, 201312 yr comment_671029 What is the point of gilmer drive anyway? You don't need pulley synchonisation on a water pump or alternator. Report
November 5, 201312 yr comment_671046 Toothed belts are the most efficient belt for those high-tech types chasing that 0.01% horsepower gain. that is until you dial the tension up so ridiculously high that your granny thinks a swarm of locusts has invaded her kitchen every time you drive past. Report
November 5, 201312 yr comment_671075 Toothed belts are the most efficient belt for those high-tech types chasing that 0.01% horsepower gain. So in a KE, almost enough extra power to run your 5W dome light... Maybe. Report
November 5, 201312 yr comment_671088 I heard on an engine like the 4k it creates a power loss as its less efficient than a V belt. Report
November 5, 201312 yr comment_671090 If it makes noise then it is by definition wasting power, as the power is being used to make noise instead of driving your wheels. Mate of mine with a 12a rotor actually has 2 V belts next to each other. like this http://upload.wikimedia.org/wikipedia/commons/4/42/Keilriemen-V-Belt.png They were OEM belts too, so nothing special ($$$). i thought that was a pretty good idea. Report
November 6, 201312 yr comment_671137 If it makes noise then it is by definition wasting power, as the power is being used to make noise instead of driving your wheels. Mate of mine with a 12a rotor actually has 2 V belts next to each other. like this http://upload.wikimedia.org/wikipedia/commons/4/42/Keilriemen-V-Belt.png They were OEM belts too, so nothing special ($$$). i thought that was a pretty good idea. That's really just an insurance policy on rotors. Due to high rpm they can sometime flip the belt over and then they don't last long at all, so the second is just a backup. I snapped my single once, half way between hobart and launy at about 1030 at night...sucked the balls. Report
