Tore's Ae86 Ground-Up Build
..and if you ever crash it you will regret the time very very much!!
Nothing like putting hundreds of hours into a build to make you a careful driver!
  • Replies 37
  • Views 76.2k
  • No rota rims here :P   Finally time to open the rear axle Pulled a axle... And its a kouki diff! My car is a zenki so its a bit of a suprise Pulled the diff out... Aaaaand its a TRD one
Haha wont use this as a rally car i promise, i have another car for that kinda stuff... Won't skid this, apart for a coupple of donuts to make sure everything is working...
Had to push the poor ke20 outside to make space for the 86 on the lift, 2tg ke30 in the background and my daily rwd tercel haha
Saddest winter in my lifetime, had a coupple of weeks with warm weather so all the snow melted :(
Edited by SM Hunter
Pulled the diff out... Aaaaand its a TRD one!! Score!
Did some more rust welding
Sanblasted all the rust in the front, sanded it all down and primed it :D
Edited by SM Hunter
Still welding
Some grinding needed
More welding needed
The orange stuff is not rust, its sound deadning from factory, intrested in how it survives the upcoming sandblasting
I'v cleaned up the underside rahter well considering it wass all Black when i got it..
Just need some money for sand to blast it with and epoxy primer to coat it :)
Some cheap idiot swapped the rear fenders, he sealed it of using tec7 and tectyl, going to blast it before i even touch the rear of the car
Progress is slow but steady
  • 4 months later...
hope so!
have to move it since i bought a HJ60 ill fix first
in the shop beside my JZA61, half done wallart by me
high...
toyota is the best
good towing car
putting it to storage till my hj60 is finished
