May 21, 20179 yr Author comment_709649 Okay to do you guys know where I can pick up a "7 rib 4age" or what to look at to know the difference? Report
May 21, 20179 yr Author comment_709650 Preferably online as I live in New Zealand so I don't know if you guys know any places here, also where can I pick up a 81 supra rear end? Report
May 22, 20179 yr comment_709653 18 hours ago, Ae70lowlife said: Preferably online as I live in New Zealand so I don't know if you guys know any places here, also where can I pick up a 81 supra rear end? Have you joined toyspeed? They may be able to help. http://forums.toyspeed.org.nz/ Report
May 22, 20179 yr comment_709678 81 Supra diff is impossible to find in australia, you might have had more ra40gt over there. Report
May 23, 20179 yr Author comment_709683 so if I were to pick up a Hilux axle for it what size diff housing should the axle be to swap a good aftermarket 1.5 way LSD? I don't want to get something too big and HD for a drift/daily car Report
May 23, 20179 yr comment_709685 HILUX = too big for daily use i reckon. I sense that our suggestions are falling on deaf ears.... first of all, you need to consider the stud pattern. A hilux is 5 stud yes? so do you want 4 stud wheels on the front and 5 stud wheels on the back? Hilux has been done a number of times, but usually they convert to 4 x 114.3 to match the front, or they convert the front to match the hilux diff. So either way you are up for a set of wheels, or modifications to axles. We put a YR22 torago differential into a mates CA18det ae86 years ago. the yr22 diff is an F series diff , which is the same as the altezza and some old supra i think (youll have to research), and 4 x 114.3 already. To give you an idea on how much it costs, diff from a junk yard - $400, Custom mounts to make it bolt in $300, custom 1 piece tailshaft - $400, aftermarket LSD KAAZ - $1200, Setup costs of the LSD into the housing and setup the gears - $300 Add it all up and not much change from $3000 just for the rear differential. also note you want to put in an aftermarket differential ONCE with whatever the most powerful engine is already in the car. Tail shafts are not cheap. Report
