B.L.Z.BUB Posted March 29, 2018 Author Report Share Posted March 29, 2018 Aldi had small fire extinguishers for only $15 so I threw one in. I bought a bunch of crap off the interballs last night. Sew on steering wheel cover, matching shifter boot, a remote locking control as the fobs dont work. A few other surprises. And some orange LEDs to match the dash to the center console and head unit. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 1, 2018 Author Report Share Posted April 1, 2018 Went to put an amp in and ended up solid mounting the shifter, making it a short shifter and using skateboard bearings for linkage bushings. Solid mounts. Shifter extensions Made some extra supports as it still flexed a lot. Gear link skateboard bearing bushes went well until the 2nd one didn't fit. But it fit snug inside this socket, and the socket fit snug inside the linkage. Overall works amazing. 1 Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted April 2, 2018 Report Share Posted April 2, 2018 5 hours ago, B.L.Z.BUB said: Gear link skateboard bearing bushes went well until the 2nd one didn't fit. But it fit snug inside this socket, and the socket fit snug inside the linkage. Yeah the skateboard-bearings-for-linkage-bushes idea was based around AE92 and JDM-spec shift linkages which had equal-sized bushes, for some reason the Aus-spec AE101/102s had unequal-sized ones (despite being essentially the same 'box) so most of the kits out there on the internet don't fit the bigger eyelet. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 2, 2018 Author Report Share Posted April 2, 2018 Yeah, my entire kit was home made anyway lol. Went good during today's Hills run. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 2, 2018 Author Report Share Posted April 2, 2018 Has an issue when going hard around corners, but only left. Cuts out power a bit. Weird. Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted April 2, 2018 Report Share Posted April 2, 2018 Fuel surge? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 6, 2018 Author Report Share Posted April 6, 2018 I have no idea. It was efi previously so it shouldn't be an issue. Plus fuel pump has been upgraded, supposedly. The coilovers were maxed out low. So I raised it 40mm and added a lip and side skirts. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted April 10, 2018 Author Report Share Posted April 10, 2018 Sewed on a steering wheel cover. So tedious. Did a half assed paint touch up. Looks better than peeling clear coat though. And fixed the fog lights. Still gotta wire them up properly. Dougie got hold of me and he's scrapping one of these in the next day or so so I'm gonna go down tomorrow and get all the small bits and pieces I need. Plus a hole less rear boot with unsmashed garnish. It's white but so was this one. Quote Link to comment Share on other sites More sharing options...
B-Lugg Posted April 14, 2018 Report Share Posted April 14, 2018 How long have you owned that compass ball? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted August 13, 2018 Author Report Share Posted August 13, 2018 I've owned that thing for a decade now. Lol. So updates. I did nothing for ages. Then motivation hit me when everything broke. So like every corolla I went to fix one thing and ended up fixing nearly everything. DF brake hardline cut off. Front soft brake hoses fouling. All coilover strut top bolts loose. Fluid change Tighten all filler bolts Wire fog lights to dash switch Install washer bottle Reroute p/s lines, solid mount resevoir Timing belt tensioner Dipstick O ring Solid mount catch can Route spark plug leads correctly Fixed rear water pump coolant weep Removed alternator and mount. Remounted with the correct bolts and the correct amount. 4 instead of 2. Refabbed the pull style p/s into push instead of the belt being stretched on. Replaced the spare wheel bracket holding the P/s pump on with the correct size bolt Mounted the water pump pulley correctly Spaced out the unused aircon bracket that needs to be there for the p/s pump mount for p/s pump alignment, used correct and right amount of bolts, same with p/s bracket. Replaced oil pressure sender Full stereo system Ducktail spoiler from an s14 Roof racks for swag Bled the brakes Tapped the threaded engine mount hole and bolted it down Fixed the loose battery terminals New remote locking controller Guard work 15x8 +25 15x8 zero Work Equip o3 reps 195/50 atr sport Pumped stock guards, stock camber Can't find pics of everything sorry lol. Quote Link to comment Share on other sites More sharing options...
Big G Posted August 13, 2018 Report Share Posted August 13, 2018 That was a big hit of motivation. Looking good. How does she drive. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted August 15, 2018 Author Report Share Posted August 15, 2018 Preservation of life is a big motivator. A lot of the service/repair stuff was completed over 3 days when I went to inspect a belt squeal. I just kept finding shit that needed to be done. The further I went it was just easier to fix more seeing as I'd already pulled shit off to repair that was blocking access it lol. One of the front tyres has a leak. Dam it. Oh well I'll take the front wheels off, put the 15x8 zero from the rears on the front and whack the 15x9 zero spare pair I got when I bought this set , that have never been fitted, on. Might need a bit more hammering, both front and rear. The pair on the front at the moment are not the same make as the other 4. Definitly not as well made as the others. Pretty sure the 4 good ones were made in the early days of rep wheels, they definitly have a much more refined, well made feel and finish. 1 Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted August 15, 2018 Report Share Posted August 15, 2018 Sounds like Braden left you quite a few little surprises to find... Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted August 15, 2018 Author Report Share Posted August 15, 2018 He was pissed he had to replace the uni on the ute. At least it wasn't a death trap. Who cuts the brake line mount off? Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted August 15, 2018 Report Share Posted August 15, 2018 "How does she drive." Yes, what's the first difference you feel when you go from a stock offset to the deep dish?? Steering quite different? I've never figured out why the world went from dished rims to flat-face, it leaves the inner rim so unsupported.. Quote Link to comment Share on other sites More sharing options...
