November 5, 20188 yr comment_715824 Hi guys can someone make a list of things i need for swapping a 4age 16v. I know i need a engine the t50 transmision what about diffs and if i use a ta22 diff how am i going to replace the suspension parts? coilovers ? shocks ? what else do i need ??? (i still don't have the car but i am doing research so this can't turn into a money pit) edit: do i need to shorten the driveshaft ? Edited November 5, 20188 yr by Dwemer centurion Report
November 5, 20188 yr comment_715825 Almost everything youve mentioned doesnt bolt into a ke35. The engine and box will need mounts made, the diff also, as ta22 is coil and ke35 is leaf springs. Coilovers can be added on any vehicle, you just might have toi fabricate stuff. Buy a good MIG welder! Report
November 5, 20188 yr comment_715826 "...so this can't turn into a money pit" haha! Its sure to!! Anyway.. don't forget your clutch setup, steering box or change to rack, LCA and steering arm dimensions, brakes and hub sizes.. Life is simpler if you leave all the suspension & brakes as they are, maybe do the conversion first and get it running, then do the chassis afterwards. You should keep the plan flexible as a lot of parts you list might be unavailable. Try concentrating on the motor, the gearbox, the clutch pedal setup and the driveshaft. Make the mounts, work out the steering so the idler arm doesn't hit the exhaust, radiator, electric fan setup, wiring, exhaust right through, get it running and tackle the rest then. A big part will be as Spirit mentioned, the change from leaf springs to 5-link. If the link arms can't fit under the floor, and those mounts alone would take some fabrication, you will be left with leaf springs on the ta22 and will need to modify the rear end to hold it in place anyway. Sure, plain leafs will work, but they will easily be overwhelmed. Report
November 5, 20188 yr comment_715827 In terms of money, to build what you suggest i would guess approximately $10k just in parts and outsourced fabrication. and about 13k total finish it off completely. Sounds like a money pit to me:) So if you got the ke30 for 2-3k, You are getting very close to $20k by the time you have done it all properly. I love corollas as much as the next guy, but a properly built 4age ke30 is still a 4age ke30. If it were me, and i wanted a 4age corolla and i had a few dollars in my pocket, id buy a ke70 with all the things already done. 4age, diff, suspension etc. prolly get one for 5k or so these days that needs some loving. Strip it down, paint and rebuild it so its in working order. You might be in 10k by then. half price and alot less effort. and apart from looking like a shoe box is arguably the better car in terms of mechanics. Coil springs, rack and pinion, ease of parts from the ae86 that just bolt in, no fabricating or modifying things. but then my name is ke70dave, not ke30dave ;) This is a little on the expensive side, but if that has an LSD in it and you could get it for say 6-7k then you are well on your way. https://www.gumtree.com.au/s-ad/kilmore/cars-vans-utes/corolla-ke70-4ag/1200132887 Edited November 5, 20188 yr by ke70dave Report
November 6, 20188 yr comment_715834 OMG! that is so typical Dave! Over-priced, well-thrashed, welded diff, no rego or engineers cert! You're right- offer the guy $5K without the wheels, then spend $5K getting it on the road nicely. Report
November 6, 20188 yr Author comment_715836 19 hours ago, ke70dave said: You are getting very close to $20k with that money i could buy a well kept running ae86 and a already built ke35 4age corolla haha. ok then i am not going to make this financial mistake even if its cool Report
November 6, 20188 yr comment_715837 Have you seen the prices of AE86's these days? You would be lucky to get change from 20k for one. That is if you can find one. Report
November 6, 20188 yr comment_715839 Yep! Over $20K for anything with less than 200,000Km. Money ain't worth what it was! https://www.carsales.com.au/cars/toyota/sprinter/ae86-series/ Even the "unfinished projects" are $9K https://www.gumtree.com.au/s-cars-vans-utes/carmake-toyota/carmodel-toyota_sprinter/c18320 Chase up parts prices for the basic engine & gearbox swap and see what it looks like Dwemer. Can you do you own engineering and welding to make motor mounts?? Report
November 6, 20188 yr comment_715840 Building cars is rarely a financially sound plan. Cars, whether projects or new, are simply expensive to own and run. At least if you build a project you own every dollar, not like when you go buy a new Hilux or something, borrow 55k and end up paying back 95 to 100k. At least if you spent 100k on an old car youd have 100k worth of stuff, and if the result is good, its still better value than paying an eventual 100k for a car that is going to be worth 22k when you sell it in 6 or 7 years if your lucky. In that sense, if you buy into a car that will or is appreciating, then you can at least be in a better position. Report
November 6, 20188 yr comment_715842 So what you are telling me is that i shouldn't buy a family car. I should buy a 911 turbo. Report
November 7, 20188 yr comment_715845 "So what you are telling me is that i shouldn't buy a family car. I should HAVE BOUGHT a 911 turbo." Price for a 1975 model was under $40K in the 1990s...... Now $100,000 to $500,000+ But yes, a car you build is a lot more satisfying than one you buy. You have to factor in a large payment for the enjoyment of it. Report
November 7, 20188 yr comment_715846 Well 1995 i was like 8yrs old. whats your excuse altezza? :P Edited November 7, 20188 yr by ke70dave Report
November 8, 20188 yr comment_715851 LoL !! I was.. ah... 46! ..but I wuz broke!! Early in the next century I paid over $40k for the Altezza... now worth less than $10K !! I never got to drive my childhood dream, a 911. Report
November 8, 20188 yr comment_715856 Yes David, dont buy a depreciating bluetooth technobox from the dealer, buy that McLaren M1 youve always wanted. its a better finacial move. Report
