AE70Rolla
AE70/KE70 Instrument cluster wiring HELP
Hey team need some help tried looking all over the net and can't find what i need,
Currently trying to  install my speedo cluster into my 1981 AE70 sedan but have a slight problem.
There is ment to be 3 connector plugs leaving the loom into the back of the dash like the first photo.
In my car i have 2 of the 3 plugs but where i should have the 3rd one i have two smaller ones that don't fit in any kind of way and have me all confused on why they are there and what they would have been for(see second photo).
Any ideas on how to fix would be awesome or if anyone has any type of wire diagram so i could try wire in a normal plug
Edited by AE70Rolla
spelling mistake
Share this post
Link to post
Share on other sites
Hi Liam,
              Can we assume that the "speedo cluster" you are referring to, did not originally come from your/this 1981 AE70 Rolla ?
If not, then what model Toyota did it come from ?
If you are marrying a cluster from one model, to another, it will be necessary to get the wiring diagrams of each, & then work out in which way they are different.
If you can answer those questions, then we might be able to get the right info to assist you.
I've been through what you are attempting, on other cars, & it can be very frustrating, getting it all sorted out.
Give us a bit more history, about why you are swapping it out.  Are you swapping out a non tacho cluster for one with a tacho ?
There is a thread on that subject, on ClubK website in New Zealand.
http://www.club-k.co.nz/Forums/viewthread.php?tid=22816
There must be a few on here that have fitted a teacho cluster into an AE70, which didn't have one.
Just found this one on this forum, from years ago.  Unfortunately, pics are not there.
https://www.rollaclub.com/board/topic/6939-ke70-cluster-upgrade-quick-tutorial/
Cheers Banjo
Edited by Banjo
Share this post
Link to post
Actually, here's the only bit you should need.
You should have white/black, black, yellow/green, yellow/red, yellow/black, yellow/blue, red/white, yellow/white, and red/blue spread over the plugs.
Share this post
Link to post
Hey Banjo,  my original cluster was lost when moving houses and i did not note what type of cluster it was, either way I'm still confused as to why i have two cluster plugs and then 2 small random plugs. I'm currently trying to wire in another AE70 cluster that came out of an 81 also. all of the wiring diagrams i have seen don't seem to match the wires i have coming out of the harness, heres the cluster I'm trying to install.
56334701_2340836272853235_3202372047334277120_n.jpg.f75de82b7444118cc5148a2f856a0220.jpg55922106_1296120720539959_1262247904261701632_n.thumb.jpg.6c9e2f0a86cf2401a0dbce0382d82ed4.jpg
Hey AltezzaClub, I don't seem to have the yellow/white wire anywhere in the harness otherwise i have the wires you mentioned spread between two plugs but am still very confused what the other two small plugs are for... do you have any idea what they could have possibly been plugged into?, is it possible for the dash to work with only 2 out of 3 plugs plugged in if wired in correctly or not?
I took a photo of each plug with wires that are in them and will write what colour they are above each photo as you may not see some of the coloured stripes,  if your able to give me your advice on what to do would be greatful as  dude
Colours from Left to Right:
Black/Orange, Yellow, Yellow, Yellow/Black, Red/White, Red, Yellow/Blue, Black
56551722_270128970536365_2911565876215939072_n.thumb.jpg.56bdfc7b054bd1046d075b332cf34a55.jpg
Green/Yellow, Yellow/Red, Green/Black, White/Black, White/Black,  Yellow/Green, Red/Blue, White/Black
56506533_326455294894933_5888786155821858816_n.thumb.jpg.c1b2ddb5084e1792a9bccf8c5328a0a2.jpg
Blue/White, Green
56541901_656532534779952_5140885813894053888_n.thumb.jpg.418e3673f9c5dc93a4b3a08b320925b8.jpg
Red/Green, Pink/Blue, Red/Green
56424358_579770442519126_6836399676694986752_n.thumb.jpg.e39dd4bdd0db9e827c10d49e9f6b2b1d.jpg
Once again any help is good help cheers team.
Edited by AE70Rolla
Share this post
Link to post
Well, straight off the diagram they should be-
Black/Orange- well, B/R is +12V from engine fuse, maybe B/O is it. You don't have a  B/R.
Yellow, Yellow,  Check & make sure one is not yellow/white, the charge light.
Yellow/Black-  oil pressure light
Red/White- handbrake light
Red- hazard relay (Europe)
Yellow/Blue- fuel sender light
Black- Tacho feed
Green/Yellow-  indicators right
Yellow/Red- Fuel sender unit
Green/Black- indicators left
White/Black- Earth
White/Black- Earth
Yellow/Green- water temp
Red/Blue- +12V in from gauges fuse
White/Black- Earth
Blue/White- choke switch (Europe)
Green- +12V for lights  but "not headlights"
Red/Green- Clock
Pink/Blue- Cig lighter
You should put a couple of extension wires on a multimeter and put one probe in these plugs, then see if it comes out where it is meant to under the bonnet or around the car. That's the only way to confirm it.
Edited by altezzaclub
Share this post
Link to post
