Turbo 7k ke10
Yep maybe.. I'm not bothered..just want to drive it..
Anyway i didnt like how you had to lean over to change gears.. So i got a custom gearknob made for b and m shifter
  • Replies 67
  • Views 10.1k
  • untubbed_20
    untubbed_20
    Put fake original ex tip on the dumpy
  • untubbed_20
    untubbed_20
    Sourced all n.o.s tierods/ballljoints,steering bush all the rubbers including the previously unattainable lower control arm bushes
  • untubbed_20
    untubbed_20
    Yep same deal Yes its just a  fun streeter/cruiser,I'm not ruining it by turning into a drag car If i wanted to go fast.. I woudnt use a k motor.  I just wanted something different
Also car never had a demister/heater so i made a plate which bolts to upper firewall gave it a squirt of wrinkle black and done.  The heater cranks.. Got it from a mini shop
Filled all engine bay holes
Mobile sandblaster is coming to do bay next week then hopefully can paint it that weekend
Went to drop of shit to mate
Heads meant to be stock... But hes coudnt help himself and has started porting it.. 😂
Engine bay sandblasted
Got all the primer /paint amd filler to do job.. But its to hot now ffs
Coming along nicely mate.
Agree, can’t wait too see more
Trans was finished january
Motors nearly done..
Just need to machine rocker posts and modify 4k trimatic flexplate for 7k
Damn cool driveline Darren!
Will this be a street car? The new fuel system looks neat, I've been tossing up one of the Pierburg lift/pressure combo pumps for my MX32 or an external surge like yours. Is this what you're using to feed the high pressure EFI pump? https://www.efisolutions.com.au/pierburg-external-fuel-pump-low-pressure-high-volu
Yep same deal
Shoudnt even be laggy at all... Only rev to 6-6200rpm aswell.
