October 16, 200620 yr comment_146738 dude love your car, where the heck do i get those guard flares from and how did you rock the motor over, was it cut on the belhousing and then rewelded if so great job as i can't see any other way it could be done. awesome rolla mate. Report
October 16, 200620 yr Author comment_146741 lol cheers man, they are ke25 levin copies (fibreglass) dunno where u could find some....? no, the engine mounts were played around with to get it to sit up straight i bought it like it, helps the webers breath. of course this makes the gearbox up on its side, it has a custom gearbox crossmember to accomodate this and also the gearstick is bent back towards passenger seat on almost a 45 degree angle to make it normal Report
October 16, 200620 yr comment_146820 hey were those suspension upgrades done on the original struts? if so could i please get the model number of the springs and inserts? Report
October 17, 200620 yr Author comment_146899 would have to find out the model numbers I'm not sure, they are ke20 hubs, KYB inserts, king springs and strup tops moved for caster/camber Edited October 17, 200620 yr by Brendo Report
October 17, 200620 yr comment_146967 Thanks the reason i asked as I'm helping on a morris 8 build and its running a 1k with webers he makes custom manifolds so that isnt a problem, but he has cut the bellhousing and twisted it so the shiter is normal, the way yours is done looks alot stronger though. I'm looking for the same sot of thing with my 11 like hillclimbs a little more, its more of a one shot deal. I'm not from tassie but i know 1:17s at symonds is a serious street/track car well done guys. Also what tyres do you use as I'm looking at yoky a032r in a hard compound. only going hard as ill also be using them for a little street duty aswell. stu. Report
October 17, 200620 yr comment_147008 Holy crap, what a machine :D Hope my 20 can have as much potential as your 10 shows. Report
October 18, 200620 yr comment_147019 would have to find out the model numbers I'm not sure, they are ke20 hubs, KYB inserts, king springs and strup tops moved for caster/camber so they are standard struts with the hubs swapped? and the inserts were just bought straight from a shop or ordered specially? Report
October 18, 200620 yr Author comment_147039 so they are standard struts with the hubs swapped? and the inserts were just bought straight from a shop or ordered specially? yep they are but the strut tops have been played around with, i dunno about the inserts, id have to look back thru the history to see if they were for another model and customised or what.... Report
October 18, 200620 yr comment_147040 yep they are but the strut tops have been played around with, i dunno about the inserts, id have to look back thru the history to see if they were for another model and customised or what.... cheers for that, that would be much appreciated. Report
October 19, 200620 yr Author comment_147186 to give u an idea of the ported inlet size, here is the manifold gasket that came off it... next to a stock 3k one, i have another one coming so i can put it back together Report
October 20, 200620 yr comment_147435 hey man how's she goin for ya? will you still be bringin it down on suday still keen to see you goin around that track! Cheers Roddick Report
October 20, 200620 yr Author comment_147461 yeah its nearly all back together but wont be goin to the track cause its been cancelled for track preping for the v8 supertaxis... i think its been moved to sometime end of november.... Report
October 31, 200619 yr comment_148986 umm thats a tad bigis that a stock bigport 3k? ummm its a 135 bhp 3k :) Report
November 7, 200619 yr comment_149961 Its not a bigport... ITS A FFFFFFFFFRRRREEEEEAAAAAKKKKKK!!!! Report
