Raven's Ke25 Corolla Memorial Rebuild - Now Parting Out
Perfect caption for the engine mount;
"You know you shoulda bought a KE70 when......"
Lookin good Mick, hope to hear some brapping while I'm at work soon >|
  • Replies 462
  • Views 416.1k
Wont be anytime soon!
Still need to get the rust sorted, but before that I'm going to source the front engine mount and make sure I know where the motor is going to mount before that stuff even gets started.
Going by that guide, I have the late RX-4 twin dizzy box with the low mount starter capable of 300hp! :lolcry:
Think I might have to stick with it! :lolcry:
Is it just a 4 speed?
The top pic of the "early GB" Darren posted is a S1 box. The S2 and S3 ones have the shifter up above the output shaft in the same sort of position as the S5 box. >|
FYI - another thing to bare in mind while chosing a box is the clutch you're going to use with it. All of the early boxes up until FC's use a 8.5 inch clutch and flywheel. FC onwards have a 9.5 inch clutch and flywheel. Your 12a would have a 8.5 on it.
If you don't want to have to change the flywheel (big arse nut and 230 odd fp of torque!) then you can run a S4/5 turbo box with the 8.5 by using your RX4 BH bolted to a S4/5 turbo box (yes it fits) and a clutch plate with the right spline for the S4/5 box.
No extra shift position when I went through the gears.
Definitely a 5 speed though. Reverse was to the right and down like normal.
Edited by Raven
My main issue really is the fact that I'm getting the car painted and rust repaired and would rather do it once and not have to make trans tunnel mods later down the track.
I'd like to get my hands on an S5 box just to trial fit it and see if it'll sit up in the tunnel or not.
Mick the box in my car isnt far off going BANG and I'm trying my hardest to make it do that haha
So when it does you can borrow mine, be motivation to pull it out and start getting things underway to repair it :wub:
So when it does you can borrow mine, be motivation to pull it out and start getting things underway to repair it :D
Well, hurry up and make it go bang so I can start measuring stuff up :wub:
