March 15, 201016 yr comment_421759 Perfect caption for the engine mount; "You know you shoulda bought a KE70 when......" Lookin good Mick, hope to hear some brapping while I'm at work soon >| Report
March 15, 201016 yr Author comment_421814 Wont be anytime soon! Still need to get the rust sorted, but before that I'm going to source the front engine mount and make sure I know where the motor is going to mount before that stuff even gets started. Report
March 15, 201016 yr comment_421843 Going by that guide, I have the late RX-4 twin dizzy box with the low mount starter capable of 300hp! :lolcry: Think I might have to stick with it! :lolcry: Is it just a 4 speed? The top pic of the "early GB" Darren posted is a S1 box. The S2 and S3 ones have the shifter up above the output shaft in the same sort of position as the S5 box. >| FYI - another thing to bare in mind while chosing a box is the clutch you're going to use with it. All of the early boxes up until FC's use a 8.5 inch clutch and flywheel. FC onwards have a 9.5 inch clutch and flywheel. Your 12a would have a 8.5 on it. If you don't want to have to change the flywheel (big arse nut and 230 odd fp of torque!) then you can run a S4/5 turbo box with the 8.5 by using your RX4 BH bolted to a S4/5 turbo box (yes it fits) and a clutch plate with the right spline for the S4/5 box. Report
March 16, 201016 yr Author comment_421851 Its a 5 speed.... I think I might go take some pics tonight and determine exactly what it is. I'm just going from memory here >| Report
March 16, 201016 yr comment_421860 AFAIA RX4's only came with 4 speeds (unless it was a Luce). So you migth have an RX5 5 speed with an RX4 BH. Report
March 16, 201016 yr Author comment_421869 It has a weird looking gear shift on it. don't know if that helps anything though. Report
March 16, 201016 yr comment_421874 Has it got an extra shift position to the left of 1st gear? If it does its a park position and its a TQX import RX5 box. Report
March 16, 201016 yr Author comment_421880 No extra shift position when I went through the gears. Definitely a 5 speed though. Reverse was to the right and down like normal. Edited March 16, 201016 yr by Raven Report
March 16, 201016 yr Author comment_422098 Had a look tonight and read the guide again....its a S1 box :wub: Edited March 16, 201016 yr by Raven Report
March 16, 201016 yr comment_422163 That'll do for now Mick. I'm running a S1 5 speed behind my 13bbp at the moment. I'd be more worries about what diff you're running than the gearbox. :wub: Report
March 17, 201016 yr Author comment_422188 My main issue really is the fact that I'm getting the car painted and rust repaired and would rather do it once and not have to make trans tunnel mods later down the track. I'd like to get my hands on an S5 box just to trial fit it and see if it'll sit up in the tunnel or not. Report
March 17, 201016 yr comment_422192 Chuck a "wanted to borrow" add up on ar.com and I'm sure somebody could help you out. Report
March 17, 201016 yr comment_422193 Check out this 12A KE25 and check out his tunnel mods, nothing to hard to do: http://www.nsdperformance.com/index.php/ga...-12a-turbo-ke25 Report
March 17, 201016 yr comment_422221 Mick the box in my car isnt far off going BANG and I'm trying my hardest to make it do that haha So when it does you can borrow mine, be motivation to pull it out and start getting things underway to repair it :wub: Report
March 17, 201016 yr Author comment_422293 Mick the box in my car isnt far off going BANG and I'm trying my hardest to make it do that haha So when it does you can borrow mine, be motivation to pull it out and start getting things underway to repair it :D Well, hurry up and make it go bang so I can start measuring stuff up :wub: Report
