All Activity
- Today
Cheers taz and altezzaclub. I might give the speedo a bit of a oil up and the cable. Could it also be the fact that its a 3 speed auto cluster with a 5 speed manual with 4:30 gears and 205/60r13 tires. All mixing putting it so far out? Cheers 79rolla
- Yesterday
I don't think it's going to be a speedo (dash) issue if it's over reading speed. Maybe the difference at 60 just isn't big enough to be easily noticed between the phone and dash. To answer your question - yes taller gears would correct it. From memory manual ke55s had 3.9 diffs. Changing the speedo sender unit could also. Probably more importantly, how does it drive? Do you like the current gearing? The easiest solution might just be taller wheels/tyres.
- Last week
If the boxes had a different final drive it would be a constant ratio out, like 6kph at 60 and 10kph at 100, so if its varying I reckon the speedo might be dodgy. You could pull the instrument cluster out and take the speedo apart to put some light oil on the shaft and bearing in there, they are driven by a magnet working against a tiny copper spiral coil spring. Have the cable out at the same time and hang it up somewhere so you can drip engine oil into it every time you walk past, until it comes out the bottom. Also a good idea with that clutch cable you've just fitted! Same with the diffs, they would be a constant percentage out. They will change the speedo by 5%, as will tyre size and going to 14" rims, but in theory its all constant. I've run a 3.9, a 4.1 and it came with a 4.3 like yours, originally an auto car. Jap cars were well-known for their speedo over-reads, along with their pony-power figures.
Is fitting the G head an easy job? The block is the same but the crank/rods/pistons are different I think. Low compression and weak internals. However, I've run out of ideas if you've checked everything we've talked about. The head gasket could leak into the water jackets, that's common, so you get bubbles in the rad when the motor is cold and the motor loses the top inch or two of water each day, but then hardly loses more. The bubbles are the compression being forced into the water system and when the thermostat is closed they push down to to the bottom of the rad and push the water out. So if you have a full radiator and the cap off when you start it and watch for a minute or two, a bad head gasket will overflow the water then suddenly burp some bubbles out and the water level drops an inch or two as the thermostat opens, allowing the compression to escape. You can buy test kits that look for carbon monoxide in the rad water to check this. The other side is that at night after a run the motor cools and that cyl sucks a little water in, which condenses on the spark plug, and when you start the next morning that cyl doesn't fire. Eventually the warm-up drives the water off the plug and away it goes, so the motor runs on 3 cyl at first startup, then runs OK during the day, just short of power. You could try fitting a new spark plug to #1 before starting it in the morning and see if it starts up on 4 cyls. A warp in the head often leads to oil in the water and vice versa, but that is usually cyls 2 and 3. A bent valve or a burnt valve will drop the compression, especially at cranking speeds, but a leak-down test really shows that. A compressor hose on a drilled out spark plug should hold pressure against the rings but drop pressure passed a bad valve or a broken compression ring. That is a more positive test than the compression meter while cranking. So, let it idle with a full rad and no cap until the water suddenly heats up, or buy a test kit and check the rad coolant. that would eliminate the head gasket. Then drill the center electrode out of a spark plug and clamp a compressor hose on it. Even a tyre compressor with a gauge would do, just blow it up to 100psi and turn the compressor off, and watch the gauge. Do all the cyls and note how fast the pressure drops. The motor will turn over half a turn as you pressurise it, its a surprise the first time! I think this is the most likely reason for it not running now, everything else seems fine.
It sparks amazingly when held to the block, it was the first thing to check before doing all other effort. There is no oil on the water. I bought it with not functioning fuel pump and I found the issue after I installed the fuel pump. Actually I installed another one just to be sure this is not the reason. So, head gasket might be the only option left and I will need to take the head off to check? Would this be possible with this compression? I am too tempted to get rid of this head as I have a GE one and this is the reason I was hesitating doing it. I was hoping for an easy project.
have you checked this one- '..and Cyl 1 will fire a spark plug in its lead resting on the head?' Just to make sure the plug does fire on the lead, which it probably does. So, has fuel, has spark and has compression.. The compression is the worry, a broken ring would drop that compression before stopping the plug firing. A head gasket might drop it enough to misfire but you would expect to see that in the compression test. Sort of 110psi for a dud cylinder, and your #1 is only 5psi down. No oil in water or water in oil?? They usually fail between 2 and 3 or 3 and 4 but maybe cyl 1 is leaking out somewhere... Which is what the Brave AI didn't specify.. "The Toyota 4AC engine is notably prone to head gasket failure even from minor overheating events, without necessarily reaching the red zone on the temperature gauge. " I didn't know they were prone too HG failure until I thought to check. So, check a definite visible sparking of a plug on #1 lead. No water in oil, oil in water or bubbles in the radiator on cold start... and list anything else you can think of. How did it start? Just one day never ran on that cyl, or were there oncoming signs of misfire?
All leads are new and all spark plugs are new as well as the distributor cap. Indeed, pulling the cable off the cylinder 1 doesn't change the work of the engine, while pulling any off the others would nearly stall it (two cylinders left). Swapping spark plugs or leads always keeps the first not firing. The spark plug on cylinder 1 turns wet and black. The one on #2 is rather black with a bit of brown, the others are rather brown Cold compression test reads 11.7 on #1 and 12 on the rest. Warm compression shouldn't be as far from this to the point to fully not ignite cylinder one.
Hey everyone. I am just wanting to know how much the diff gears may make a difference to the speed that the speedo is showing vs the car is actually going. The only thing that I have done is change it from a 3 speed auto to a 5 speed manual. The car still has the 4:30 gears in it. And with those gears from about 60km/h up the speedo is out. At about 100 by phone, the speedo sits between 110-115 km/h. But at 60km/h the car is doing 60km/h by phone. So I'm wondering will 4:11 gears fix this problem or make it worse? Cheers 79rolla
Tricky... So is the cylinder ID from pulling a spark plug lead off when running? Number one didn't drop the idle speed? What were the compression readings? Is the spark plug black or clean? Colours of the other 3? ..and Cyl 1 will fire a spark plug in its lead resting on the head?
el_camino started following Wicked issue with 4AC
Hello guys, I am trying to build love to a good condition AE86 with 4AC and keep it original for the moment. There is not logical issue however and being out of ideas I am reaching out for help. The cylinder one refuses to work, no matter what. There is spark, a good one. Distributor revised. There is fuel. Tried with different carb from working 4ac. There is good compression on all 4 (12). Valves have been adjusted 3 times and are in spec. The car is running smooth on the other 4 otherwise, starts first try. Runs rich, I assume due to the not burned fuel in cylinder 1. I am really out of ideas what to do next. Anyone had a similar problem and ideas for testing please?
el_camino joined the community
- Earlier
KE70 - Fuel gauge drops when headlights are turned on.
focus218 replied to focus218's topic in KE70 Technical Questions
Received it a few day ago and did the installation but the problem is still there. This is next -
bigport TVIS mod to all 8 ports.
altezzaclub replied to altezzaclub's topic in AExx Corolla Discussion
Ok, that is all changed now, and I thought I'd make a separate topic of it. It has eight alloy inserts in the TVIS plate, and the smaller diameter ports have made all the difference. This is why people say Toyota made the bigports too big! https://www.rollaclub.com/board/topic/85687-bigport-tvis-mod-to-all-8-ports/ I'll stick with that while I get the extractors moved, get some stone-chip spray on the sills and do some tidying up. Overall, its a big improvement around town and on the 40km cruise to Redhead Motorsport and back each day.
Well, the Girls KE70 has had the 4AGE for 5 or 6 years now, and more recently a Haltech running it. Behind that is the lightest flywheel I've ever seen, and a pair of Wade 267deg cams, extractors and a 2" exhaust, all on the stock inlet system... It has always been a dog low down, even with a stock ECU it couldn't hold an idle, and the last mods were Banjo making me a Hall Effect sensor setup for the distributor and a set of COPs. Then it died earlier this year and I found enough carbon under the valves to drop the compression at cranking speed, and the TVIS plates heavily carboned up. Having made some movies under the inlet system with an iphone I realised the Haltech told the TVIS to open up or close but in the wrong language! They had been open all the time! I found an output in the Haltech that worked like I wanted, but opening them was nothing great.. I could move the opening of the TVIS throttles anywhere in the rev range and nothing made a big difference. The 4 ports usually open can do what the motor needs. So I figured I'd get rid of them and run 8 throttle plates against the head and no throttle body, using the stock 8-runner inlet. First up was a look at Garage4AGE and his dyno runs. All the power increase is before 60% throttle, then you get diminishing returns. Then an excellent tuning page I came across, giving the max power per throttle body size. https://engineeredbydesign.co.uk/Pages/Calculators/ThrottleBody.php Stock is four 30mm runners in the TVIS system, with 4 closed. That is good for 220KW at 7500rpm Open the other 4 TVIS 30mm runners and its good for 440KW!! The stock 55mm throttle body can power the 220KW that takes 4 TVIS runners, although 60mm would be better. Which brings up a interesting question, does one throttle body of a certain area flow as much as 4 ITBs adding up to the same area?? Each ITB flows once in 4 strokes, then it flows nothing for the rest of the time. A single throttle body flows its max all the time, just dividing that air flow from one cylinder to the next. So in theory I think the 4 ITBs should be smaller than a big single.. Anyone know about this? OK, meanwhile, everything is waay too big for what I want. I put in a 1600cc V8 to get figures for 8 runners working, one for each valve. To get 125KW at 7500rpm needs eight 14.5mm runners!! Far too small to even engineer, so I worked on 20mm. In theory that is good for 200KW, matching the stock throttle body, and not many slightly modified 4AGEs are going to worry about more than that. These are 20mm coins in the 30mm holes of the TVIS gasket. So while Josh was away for the ARC round in Tassie I bought a 33mm round bar of alloy and got on the lathe. I made them 30mm long so they stick into the head close to the injector, stepping them from 30mm OD down to 25mm OD as the port reduces in the head. Then I put the inlet system back on. Did you know you can remove the stock inlet system and leave everything else like the injector rail on? Toyota were very neat with this design. Instantly the motor idles now, from cold even! Pulls up the driveway without lots of on-off-on throttle trying to work the revs up, and cruises easily around town at 50kph. I have nice long hill just of of town that I time 60-100kph in 3rd from a particular roadside sign, and its gone from 12.23sec to 11.8sec. That's 3000-5000rpm, the most useful range for daily driving. I haven't found any loss up to 6000rpm, I don't need more than that, and everything below is better. I've been changing the Haltech fuel cells all week as it suddenly ran lean, more air getting into each cylinder. I'm dying to see the fuel usage after a tank full. I can put the original TVIS throttles back in, or I can drill right through the lot, mount tiny 20mm throttle plates, put a cable in the middle where the TVIS actuator is and a TPS on the back by the firewall. Then it needs a vac system for the brake booster or unboosted brakes. Then you get instant throttle response. I'll see how enthusiastic I am in 6months!
Banjo started following Corollas are Never Too Far from the Headlines !
With the motor media almost completely overwhelmed, by talk & discussion about EVs; it is always a treat to read the news;; & read a story today, about an "olde skool" Corolla. Olde Corolla, Does the Gibb River Road in Style Full Marks Jonny Charles ! On top of that, He serves coffee to other travellers & calls his on wheels coffee outlet; "Cafe Corolla" https://www.facebook.com/10newsplus/videos/meet-the-man-driving-a-café-in-a-corolla-around-australia-10-news/1047960244629879/ Cafe Corolla gets to Mt Hart 💪🇦🇺 | Jonny Charles | Facebook https://www.facebook.com/josh.ball.56679/videos/jonny-flying-through-the-gibb-river-road-in-a-toyota-carolla-so-stoked-to-have-r/1424096706406376/ We salute You, Jonny Charles ! Enjoy ! Cheers Banjo
I also loved Korean comics, and webtoons too!! my fav one is lookism.
Banjo started following ig: siamrat_ss Toyota Publica with 3K Clean build. , Gjm85'S Ke20 Build and Small Cars
Hi Gavin, Nice to see your name pop up again. Cheers Banjo
It's been a long time... but i remembered my password.
https://www.msn.com/en-au/motoring/performance-cars/the-fantastic-cars-that-put-the-world-on-wheels/ss-AA29tSGB?ocid=msedgntp&pc=U531&cvid=6a7abfff2b914bd7ae32f0c0e9b7e38b&ei=86#interstitial=7 You'll love some of these ! P.S. And "yes", there is a Corolla in there ! Cheers Banjo
altezzaclub replied to knibusu's topic in Rollaclub Rides
How do you reckon that throttle disc transfers rotary motion into vertical motion? I haven't seen that before. An arm stuck out horizontally underneath, pulling on the usual ITB shaft arm and rotating it? -
Banjo replied to knibusu's topic in Rollaclub Rides
Yeah ! Very much for "show only", & quite a few things needed before it heads off to it's destination, as Taz mentioned. Hmmm ! Interesting mounting of the four (4) C.O.P.s. They look like Denso style COPs.. I can assure you they do not sit that low in the spark plug tubes; unless they have been cut down in length. If they are, Denso COPs, then it is for show, as the primary & secondary coils are wound on top of each other, down the long tubular section of the COP, which pokes down the spark plug well in the head. The only COP type that you could use is a type that has the coils in the head of the dumb COP; & nothing but a long spring in the tubular section. I've just recently given away the "intelligent" COPs, as they combine the chassis ground connection for both the +V trigger signal return; & the coil charging +12V chassis ground return. I've just done some tests on a Ford Falcon BA series "dumb" COP, which has no ignition or smarts in it at all. It has just a primary & secondary coils in the "head section", which is taller than your average COP; as depicted in the photo below. The stork on the BA series Ford COPs, contains just a long spring to transfer the HT voltage to the spark plug. Actually, the Ford BA series COP could be shortened so it just stuck out of the spark plug well, like those in the "engine bay" photo above. Might have to give that a try. The mounting rod looks really simple, with four "pads" welded on to secure the COP hold down bolt. P.S. These BA Series Ford dumb COPs, really pack a punch. I've recently done some tests on one, & is packs a real punch, & charges up to 12 amperes, in just 4-5 m/sec. Cheers Banjo -
Taz_Rx replied to knibusu's topic in Rollaclub Rides
Engine bay pic is 'Instagram finished'. 1 there's no wiring to the coils or CAS, and 2 there's a water line from the water pump that goes into the timing chain cover. Water cooled timing system? 🤣 Other than that it does look cool. -
It does look like they are getting every horsepower out of the 3K that they can! -
Hey Guys I do not own this car, I just came across it on facebook, not sure if its been posted before but look at this. Looks like alot of work has gone into this car. I came across his instagram to: https://www.instagram.com/siamrat_ss What a wonderful build.
Jetpat started following Ke30 corolla Nov78
I have to admit that was my first thought, but there are no death notices! I checked....
