seems like a lot of people are doing entire strut conversions to
get an easy brake / spring / damper / camber upgrade.
ke30:
i know the corona xt130 are popular and are almost
a bolt in fit?, as well as doing the pug hilux brake upgrade on them.
ke20:
celica ra40 struts and control arms?
any others?
Edited by styler
RA40 celica struts bolt into a KE30/55
Could possibly do that to KE20/25 too, but I'm not sure about obtaining any negative camber with such a large spring diameter.
You'd wanna go coil-over conversion to get negative camber though.
i have seen people use datsun struts in ke10's, i would like to know a bit more about it, my mates old ke10 had stanza front struts and a 100kw 4age, the struts were supposedly fitted with not to much hassel, anyone know about it
I'm pretty happy with my standard ke10 struts with ke20 cut down coils and removed transverse leaf
i just put ke30 struts with ra40 strut tops, lower control arms, tie rods and steering arms into my Datsun 1200 ute, so i guess you could interchange parts.
I'm going for the coil-over conversion.
RA40 struts, pillow-ball bearings, camber plate, top-hat etc etc.
I might bite the bullet and go for the Noltec Kit yet....
Edited by Raven
cool, i might have a bit of a mess around with my new ke38 when i get it to try and fit some datsun 240k struts i have into it, just for a bit of fun,
the only reason i used stock struts and stock springs etc is because i can't afford anything dear, i am just using what i allready have,
hmm
for a ke30, the easier jobby is to use ta22 struts and lower control arms...
just gotta swap over the strut tops - child's play, and bolt up the control arms ...
I'm doin this soon... its good coz stock corolla vs stock ta22 celica suspension - the celica stuff is seomthing like 30mm lower standard.. so the idea is to get ta22 low king springs and some shocks - and you're ke30 will sit low. tyre shouldn't be much above the guard :P
ra40 gear has bigger discs and stuff, but not as low ...
hope this helps
dyzza
86 struts are the same diameter and bolt spacing as RA40 on the bottom of the strut as far as I know....
Edited by Raven
Apparently they also have the same bolt spacing at the bottom of the strut as RA40.
Only difference between the two struts are the diameter of the centre hole of the disc and the fact that its vented.
I put the strut, brake and control arms from a 85 supra in my ke70. (I think they are the same as celica?). They work great and i can lock it up at any speed. However it raised the ride height and gave me positive camber. very easy conversion
Shorten your struts to reduce the positive camber.
I'm now wondering if RA60 Celica struts will fit on KE30 LCA's because if they do, I'm going vented discs in my KE25.
