Trev's Ae71 Sedan Turbo Project
Hey guys, AS you know from my signature I am in the process of building a 4AGTE AE71 sedan, I have not got everything to complete it as yet so i am going to use my spare bigport GE and run it N/A until I can gat a bare Bigport GZE, I will be running the factory auto until I get the GZE then the auto will be off to get a stally and a shift kit (I don't care how gay that sounds to some), The main thing at the moment is I still need to convert the fuel system to EFI, I will be separating the GE FWD harness to run engine only and keep it separate from the factory harness, I'm just waiting for the engine crane and my stand so i can get stuck into it.
Also my JDM RWD Bigport inlet manifold is still on a boat from the US so i have to wait for that.
I have taken a few pics:
The beast:
Where the power will be housed :wink:
Decided to insert the clock and tacho into the original dash (160,000km's):
The only bad spot:
The original auto:
The donor 4AGE:
The spares Seca:
Where it's happenin:
Rear shot:
The turbo parts:
HKS 4age turbo manifold.
GT25/74 Garrett Bush turbo.
Turbosmart Dual Stage Boost Controller.
Autometer sport-comp boost guage.
Autometer matte black cup.
Turbo Piping.
(FMIC is not pictured)
My shed (holds 4 - 6 cars):
The carport (holds 5 cars)
Will have more of an update once i get the crane and stand back.
Edited by Trev
  • Replies 233
  • Views 91.8k
Oh look you ae71 is jacked up like my ke70.
:wink:
Youve seen it in the flesh, U know i want it lower :cool:
Yes he has pics up. Looking very promising, trev. I wish i had the facilities that you do as far as car storage goes. That shell looks nice. Very exciting.
:wink:
Bring it to my house then.
hahaha theres photo's on here somewhere of my orig Ke70 "jacked" up that way aswell.
Today I started labeling the FWD harness so i can start to cut it up, I also took note of where i want the harness's fuse box situated when it goes in the AE71:
Edited by Trev
I have decided to track down a JDM T50, Why JDM, Well the clutch fork is on the drivers side so the turbo dump wont interfere with it.
Got the engine harness out:
A few pics of the turbo mounted, Yes its mounted in the seca:
I'm not really happy with the direction of the compressor housing so i might get a custom waste gate actuator made with a zig zag shaft and mount it on the back of the housing so i can have the compressor outlet facing down.
Edited by Trev
Why are you putting a manual gearbox in it now?
Edited by Corolla_Kid
Ha, Peer pressure.
Mainly due to the fact that I'm going to need an 8 bolt flex plate in the long run, I will hold onto the auto and might give it a run one day when the car is fully complete, A project never goes to plan tho, You will always change your mind about something.
A few pics of where the DSBC & Boost Guage will be located:
Pulled the rest of the harness out just before:
This is what i have to work with (probably do it tomorrow):
Going to strip all the engine related stuff from the ecu plugs, I have the manual so i know what pinouts are what so its a big help:
Progress, awesome. Peer pressure, hahaha. If you can't find a jap t50 its only gonna cost about 65 bucks to get a hose made to fix the interference, cheaper than a 500 buck jap box...
Looks great anyhow, trev. That manifold does a nice job of keeping the turbo near the block.
It was nice meeting you and Brad (Beerhead) today :D
I haven't done much too it lately but the engine harness is pretty much all done, I am upto the stage of doing the 14P plug on the ecu.
I took to the harness with a multimeter today and decided to find where the engine harness ignition power comes from and what size fuse to use so i am going to take what info i have from the harness, Run a relay and splice the trigger into the ignition "ON" output and run an inline fuse holder with a 7.5A fuse.
Here are a few pics:
