Ke20nut
    94
Everything posted by Ke20nut
  1. hi , am just wondering what is an easy replacement fit for a ke10 brake master cylinder. i have heard of a mazda one being a close fit. preferably want to fit a twin port master cylinder . Can anybody who has done this give me some tips. i don't want to modify the firewall too much . thanks
  2. how much did u guys pay for a kit when u ordered in bulk. who is the main man to speak to in aus to get this thing rolling again
  3. does anyone have the guys phone number so i can contact him to make me a set
  4. Hi i have a set of corolla tail lamps. I believe they are off a wagon possibly a ke26. I'm not 100% sure can anyone confirm what they model they are off? they are a koito toyota tail light . Melbourne
  5. Seen a kermit green ke10 or ke11 today cruising along in melbournes west today, didnt get a good look cos i was stuck at the lights. Had big black mags and was kermit green and sat on its arse. looks awesome . Does anyone know whos car this is and if he or she is a member of rolla club. I'm intersested in some more pics
  6. give pete a call a Hoppers Stoppers in victoria (hoppers crossing) he has engineered complete brake set up kits for twin piston calipers . or google him he has pis on the website
  7. put pressure on the tie rod end. Use a piece of timber jack it up under the tie rod end till it touches. don't jack the vehicle from this piont as u will bend the rod. place enough pressure on it in an upward direction , then try undoing the nut. it will work .
  8. try a cable place, get em to put a new insert cable, thats only if the outer housing isnt frayed or binded. shouldnt cost more than 50 bucks. i had mine modified for a ke10 for 20 bucks in melb
  9. are the shocks custom made or a shelf item
  10. got a good set of full chrome for the front windscreen whats it worth to ya
  11. i heard these under dash units are now illegal is this true. i believe its only illegal if its a modification, as vans are still made with an under dash unit. am not 100% . is this true look into it
  12. bigger engine wouldnt make a difference, if the final drive is still the same, will still rev high! try changing the diff then youll see a massive difference, and maybe a 5spd even better
  13. give me the addresses of these wreckers with early corollas ke10 and ke20s, i will plan my two weeks off and have a trip to the yards up there , my god ill be cashed up for sure to save em
  14. thanks but the book doesnt list em so i guess ill need to make em . get well soon
  15. do i need top make ke10 front control arm bushes or can i get em somewhere. I'm sick of talking to dicks in shops. u guys and gals on this forum are like family to me now :P
  16. ah no way , ive had nothing but trouble getting bushes, the only ones that seem readily available in melb are the rear shackle bushes. use the falcon rear shackle bushes for the front eye bush, which they say are available but are the wrong ones that they supply if u need more info email me and ill give u my ph no so i will answer any question i can.
  17. yes the ones i got that were wrong were superpro. the only thing i got out of super pro was a bloody sticker :P
  18. i am currently replacing all the suspension bushes on my ke10. i had no trouble finding rear shackle bushes in nolathene. When i asked to order a set of front eye bushes they arrived but werent the correct size. we double checked with the manufacturer and they claim they are the correct ones. the size i received were : 50mm diameter at the bush end 10mm eye bolt hole the ones that come out of my car were : 35mm diameter at the bush end 8mm or so eye bolt hole I'm just wondering if anyone out there has had the same problem. : Is it a manufacturers fault listing a wrong part no. : or does this part fit a jap model and not an aust model : or is it just the shop i bought it off stuffing it up. i over come the problem by using xd - xf rear shackle bushes ( rubber ones ). had to cut a few mm off the ends and use a crush tube, but they fitted perfectly. Most of the time spent was cuttting the rubber straight and carefully so as to not loose a finger . i am curious as to why they list it but its a far bigger size?
  19. do u need to leave the leaf spring in or take it out completely? u say remove then u say it will dive excessively under braking if u remove a leaf or two? do u need heavier coils from a ke20?
  20. the after market sway bar how would i mount it, do i have to drill anything or weld brackets etc , pics would be nice
  21. so ur life is only worth $520 . good to hear even better if u take someone elses life with the $520. Never grind calipers. the manufacturer wouldnt put all the metal into it if it weren't needed. they would have saved thousands of dollars building cars if they took 10grams of metal off each caliper they added to a model. the metal is there cos it is helps with the structural integrity of the caliper. so don't grind em ;) :(
  22. hi am just wondering about lowering the front end of my ke10. it has a macpherson strut set up with a tranverse leaf spring. I have been told different things about lowering it. question is do i need to get a new transverse leaf spring made up or will it go low enough if i just change the coils to 40 mm lowered. i was told the transverse may not allow the front to rest down enough , hence meaning the coils maybe loose on the macpherson strut where they seat . is this true and has anyone out there lowered theres. And i don't mean lowering it by chopping the springs or removing the leaf spring and throwing it away . i lost a mate in a car with chopped springs was the main cause of the accident. your help will be appreciated
  23. IS SOME AFTER TAIL LIGHTS FOR A EARLY KE WAGON. I JUST MAY HAVE 2 SETS IN MY GARAGE LET ME KNOW IF THEY WANT EM FOR A $
  24. THANKS EVERY ONE THINK ILL GO DOWN THE ROAD AND SEE THE METAL FABRICATORS THIS FRIDAY AND SHOW EM WHAT I WANT. NEEDS TO BE LASER CUT . CHEERS
  25. i have a feeling this used to be my car around 8 9 yr ago. was in werribee sold it to a dumb kid . he whinged about the price and called it a bucket of shit. it was the best one i ever owned at the time . drove like a new one. the interior was immac
