oke020
    347
    2
Everything posted by oke020
  1. Hey guys, yep the 1uzfe-t KE20 ran 9.92 @ 137, unfortunately the car pushed through the foot brake on the line a bit tripping the beams a few tenths before i let it go. The car has no roll cage or harnesses etc so i was only ever going to get one pass. The resulting 60' was a 1.72 where as in reality it would of been closer to a 1.4, I did not realise i fumbled it and it felt strong so i made a pass out of it. Luckily it still went a 9 which is all i wanted to do with it, 1 tenth in the 60 is usually worth 2 at the end so i am thinking it would of went 9.50s fairly easy. Pretty happy with it, it runs a stock 1uzfe + arp rod bolts, commetic gaskets, arp head studs and upgraded valve springs. The turbo is a copy gt42 and the gearbox was an unknown $150 special with a few mods. The ODU400 plates are the original plates from the 2JZ ke20, some people think it means DO U in 400m, I usually run those plates on whatever my daily drive is. Jordan - this car runs stock leafs + caltracks on a shortened 1 tonner 10 bolt diff of all things, the 2jz car runs stock leafs, caltracks, 2 link and a large anti roll bar similiar to what they run in door slammers & a hilux diff. Some pics from wednesday night
  2. I started again on this progress about 3 months back. 4 days out to powercruise and still alot to go. And some 'testing'
  3. don't forget the 110kg driver haha
  4. Very cool :)
  5. oke020
    Oke020
    Thats cool was not having a dig
  6. oke020
    Oke020
    Incorrect, the sparks the other night were from the tailshaft hitting the floor, we since fitted caltracs in the last week to fix this, the crank had no end float issues, never has, engine failure was due to massive stock main cap failure, quite catastrophic haha, will get some pics. Pretty stoked with the 7 though :)
  7. oke020
    Oke020
    Hey thanks for the comments :), i am fairly certain it could of went 1000 without gas given another run as the tyres were up to temp, also both passes archie got off it at 7800rpm which is 1000rpm short of where it feels to lay over on the track. Depending on driveline loss 928 might even come close to 1:1 engine hp : weight, car is 1236kg. With the bottle on i'd expect the rwhp figure to be near or just over 1100hp. Here is another vid from the andra jamboree footage last week.
  8. Yeah good show mate, last pass looked a little loose :)
  9. 1.42 thanks mate
  10. Probably should add mine here 1/4 mile et 8.03 @ 176mph 1973 KE20, 2JZ-GTE, street radials
  11. Stuff me what they were on about then, can't wait to see it go down the track, should be a very fun ride :)
  12. I heard a rumour that you'd given up on this project to buy a house?? but since this update i am now assuming a change in driveline plans?
  13. oke020
    Oke020
    Was a good weekend, ended up winning Modified 10.5, top qualified and won best burnout. Last pass was another 8.07 @ 176.95 so so close. You can see whats made the difference in those 2 pics above. Left pic from the nostalgias has pedders heavy duty springs and no strut travel limiter, pic on right from jambo is using king standard springs and chains to limit downwards travel
  14. Agreed, super tidy!, providing i don't break my car at nostalgia / janboree will see you ate powercruise
  15. oke020
    Oke020
    Cheers, at powercruise it was on pump/tol fuel with about 35 psi of boost in it. I think there is quite a few blokes keen to take it down at the next powercruise, i have a new progressive boost controller and might bring some decent fuel to keep them honest :jamie: Yep it fries coming onto boost in 1st then sits at about 8800rpm in top, with the 3.5 final ratio thats just on 300km/hr tyre speed haha
  16. oke020
    Oke020
    Found a few vids from the Powerplay drags, here is a cool one lol, didn't think it turned them that hard :)
  17. Thats awesome power for the amount of boost. I can vouch for the corona 4 speed, noisey, leaky but strong :P been seeing your car around been meaning to have a look, looks very nice indeed.
  18. oke020
    Oke020
    No worries mate, struts are all good it seems, will need to do something about those strut tops though haha
  19. oke020
    Oke020
    For the first time ever i took no vid cam, should be a few people that got vids from the wall though, i will just have to wait to they put them on youtube or something i guess.
  20. oke020
    Oke020
    Yeah was a 2 link setup issue, all in all was a waste of a night. Took OKE020 to Powercruise Powerplay today, on pump fuel took out the off street drags final :D
  21. oke020
    Oke020
    Cheers ;), i got a new box of tricks for OKE020 to hopefully elimate the time lost trying to control wheelstands. If i can get it all installed tomorrow then i should be out at willowbank saturday night.
  22. The 1jz cortina, was that the red one?
  23. MV must pump out lots of exchange a340 valve bodies :D, i'll be sending my supra one in next month aswell as another for a turbo 1uz i'm doing, that plus 4-5 odd in previous years. Not only saves the box but makes over a full second difference on the quarter to :D
  24. oke020
    Oke020
    Final from another angle
  25. oke020
    Oke020
    OKE020 ran 9 or so passes over 171mph this weekend. Engine is still going strong, powerglide is hurt though. I won the final of Drag Radial at the Street machine Pro Street Nationals and made the quick 8 at 1320x :jamie: here is a vid of the last 3 passes in the radial class, gearbox was hurting on the las 2 passes hence the short burnouts, also broke the wheelie bars off on the saturday so kept launches soft. And here is incar of 2 passes, 1st pass obviously had a bonnet issue lol
