December 18, 200619 yr comment_155943 hey how are you all? I want to deck my ke55 but I'm not sure where to get the lowering blocks for the rear... For those that have decked there rollas what steps are needed!!! for rear? Cheers Richard. Report
December 18, 200619 yr comment_155945 You can makke your own lowerinng blocks to the sizee you wannt or head to autobahn as they sell them. Longer U bollts will be needed aswell. Rolla_boy is the king of low for ke sedans.. Report
December 18, 200619 yr comment_155953 The best way to lower the rear of your corolla is to get the leaves reset, or if you are dodgy like me, you can flip 2 leaves over, and it will put it on the bump stops. Lowering blocks suck Report
December 19, 200619 yr comment_156072 Agreed, lowering blocks do suck. I had 2 rear leaves reset with the eyes reversed with 2 new leaves as well as a new leaf in my transverse leaf and it reset for 200.... Resetting 2 rear leaves should be cheap as chips... Report
December 20, 200619 yr comment_156238 yup ... when it comes to corolla mods you're definitely got a guru there in rollaboy ... as he said, the ideal way of lowering a leaf sprung car is to have the springs reset ... closely followed by just flipping springs ... but I have to admit the only problem i've had with lowering blocks is that the ol' beastie is more or less on bump stops and the ride is fairly unforgiving ... but then again ... they're 3" blocks :'( Report
December 22, 200619 yr comment_156559 yea don't get lowering blocks does the same job as flipping the springs, the best value would be to get them reset, i have mine flipped atm and there is no suspension travel in the rear at all, its funny watching girls titties bounce haha but reallll dangerous so i will be getting them done properly now Report
December 26, 200619 yr comment_156942 what about just flipping a single, not two springs? is that going to lower it, but not as much? Report
December 26, 200619 yr comment_156944 how about you invert a spring pack to bring the axle up higher while also increasing the spring rate to lower the car? Report
January 11, 200719 yr comment_158919 yeah good advice above, definately don't go lowering blocks. at $100 anyway! rather invert the leaf pack and add a leaf if wanted, its the best way to lower a mild amount, which retains the original suspension travel. else if after more lowering, invert and reset at a slightly lower height. Report
January 22, 200719 yr comment_160562 how about you invert a spring pack to bring the axle up higher while also increasing the spring rate to lower the car? what do you mean by invert a spring pack like flip them over? got any photos Report
January 23, 200719 yr comment_160800 with my 55 i just flipped the whole pack over as they are and it sits hard on the bumpstops Report
