  • Replies 100
does anyone know were i can get a reco 45 mill sidedrawft webber
the webbers i gor with the 5k are stuffed they need a full rebuild and it would prob be cheaper and easyer to get 2 reco webbers :P
If you buy second hand Webers, you still need them looked at by a professional, due choke sizes, jets etc. New 45's are about $650 each. Second hand aroud $300 each, then rebuild. It would be cheaper to get someone competent to rebuild yours, or at least get a professional opinion that they're rooted. I suggest the Carbtech in Redcliffe, Iain did mine and they're superb. He's not particularly cheap, but the job will be right. I would not hand them to anyone else. Warning: If you don't like spending money, don't play with DCOE Webers..... fuel economy on my 3K is one litre per 8 kms on transport, and one litre per 3kms in competition, and parts aren't real cheap, either.
P.S: One "B" in Weber.
1 litre per 3 km? Wow. Now THAT's fuel economy! :P How much fuel did you go through for Qld Challenge? I used about 3/4 tank or something, and that included driving to Ipswitch.
I've heard from several other sources that Iain from Carbtech is the place to go.
man...lucky you don't run 110 avgas...expensive shit ehy...well i guess you work at the airport so that kinda helps...
Its mind boggling to figure out what the hell the engines doing with all that fuel.... :P
I wish I could run AvGas, I can get it cheaper than what I'm paying for Ultimate98. After talking to Iain, he was saying that in the Evo7 they get 1.2km per litre in competition, using $7 per litre Elf Turbomax! I'm not bitching too hard about fuel costs! I used about 35 litres on the Challenge.
Justatoy, remember, most parts needed are x4 if you have twins, 4 chokes, 4 jets....etc. They really need a dyno once they're on, too.
what RON rating is avgas? can you tell a car's running it from the smell (say as badly as lpg)?
110 octane is the leaded stuff....It should be fairly expensive because the lead they use is only produced by one company in the world...and its in the UK
Now for my 3rd post in a row
Just a warning. don't use any avgas OTHER than the leaded 110. All the other avgases for piston aircraft are down around 70-80 octane
back to the burnout comp - i wouldnt bother with a k series corolla, a 265 valiant is the ultimate cheap skid machine... soak some tyres in diesel for a few weeks and you have yourself a trophy winner :P
