13b Rotary Conversion - Ke70!!
Hey everyone ,
pretty much where I'm at ive decide to do reseach an see if possible i can put a 13B rotor into my ke70,
pretty much after general chat chetter , advice an tips
maybe somone has done this conversion an could help us out ??
Cheers Brennan
what state are you in? i'd check with an engineer if its going to be on the road.
Hey everyone ,
Cheers Brennan
If your in VIC, scrub the idea of having it engineer approved. 12A would be the nearest option.
But book an appointment with an approved engineer (from your state). They should be listed on the Road Authorities website. First appointment is generally free, and will be able to tell you within a few minutes whether it is possible or not.
He simply takes max power figures from both engines, does a few calculations to see whether the power gain is within the allowable tolerance for your given car.
Then from there if its possible you can run with it. If its not possible, he will advise on what your next available option is.
Either way, if you want the conversion approved, you will have to be in talks with an engineer. So you will have to bite the bullet and see an engineer. May as well get the approval straight from the horses mouth.
Edited by kangaroosa
rotary's are expensive, engine mounts, cooling system, fule system, gearbox, gearbox crossmember, exhaust, probably custom tail shaft, u'd want a tough lsd diff, they'd make u do breaks , and you'll want stiffer suspennsiuon
Is it gonna be stock efi or A webber set up. what year did the 13B come out of. :wink:
what year did the 13B come out of. :D
Some time in the 70's
Jordan
Wouldn't bother with a weber unless you are going for a largish port. 13Bs first came out in RX4's I think 1973 was the first model. A rebuilt 12a or 13b isn't cheap, and a non-rebuilt one isn't worth it. I own one and love it, but there are cheaper ways to get performance IMHO.
My mates got 12AT RX7 and thing goes. I reckon a 12A KE70 would fly courtesy of the power to weight ratio. 13B would be nuts...and most likely illegal :D
i have a full rotary conversion kit for a ke70... all you need is the motor :D pm me ...
No peddling please mate, PM him.
didnt realise it was 'illegal'
  • 6 months later...
Hey guys, hope i'm not hijacking the thread but i'm looking to do something similar but with a Ke55. And ideas on a 13B Bridge-port in one of those??
Cheers! Once again, sorry if i'm thread-jacking!
Ev..
  • 1 year later...
i have a full rotary conversion kit for a ke70... all you need is the motor :) pm me ...
Hi i know this was posted 3 years ago buy do you still have the kit and at what price.
