67Rolla Finally Back On The Road!
67Rolla-Ken
lookin scmickooo.
have your gaurds and apron all been test fitted along with your headlight surrounds etc etc ??
you would be angry if it didnt line up after all the effort that has gone into making this thing overrated.
as for your boot badge, just redrill the holes.
you need to run that badge!!!
youve got your work cut out for you from here champ.
keep us posted.
cheers, scott
Tell me about it. I don't know where to start??
The panels have all been fitted, then taken off to prevent damage while the engine is getting sorted.
I'm not sure what to do about the crack in the paint below the VIN plate..?
Also I don't know if I can just re-drill holes for the 67 boot-badge, I seem to remember it having a groove it sat in?
Yep doesn't look good!!!!!!!!
I've got good condition chrome strips for the sides, but none of the bolts/clips to put it on with.
Would you have a perrrrrfet set of tail lights? :'(
Yeah all the clips and bolts come with the trims.
Nah only ones that have good bits on them, you can rebuild them by changing bits around etc.
Matt
Edited by madrolla68
Just watched Madrolla's idling video.... I want what he's having!!
What cam grind would give me performance (weekender, some strip work) and a nice sound? Not expecting anything like that mad mother, just a bit lumpier without being a tool...
I got a niiieeeccce one here just for you, but youll need to go to solid lifter setup.
I can get one ground for you if needs be.
Matt
