April 13, 200818 yr comment_239153 Just considering all my options with engine conversions. I thought i might try something different. Rather than the usual CA18DET 4AGE 4AGTE. I have seen a video of a trueno that had done the conversion in japan but other than that i haven't seen anyone else do it. Report
April 13, 200818 yr comment_239221 whats a F20c?? never heard of one before. just wondering CHEERS Ryan Report
April 13, 200818 yr comment_239249 Yep S2000 motor. Jump on toyota3tc.com and search for the TE27 F20C on there :) Report
April 14, 200818 yr Author comment_239339 Yeah thats the idea but i don't think i have the funds to back it up. It would be nice i think the f20c is the most powerful stock 4cylinder street engine that i know of. Unless anyone knows of anything else. Report
April 15, 200818 yr comment_239543 F20C Induction Aspirated Power 176kW @ 8300rpm Torque 208Nm @ 7500rpm-7500rpm thats more power than a standerd rb25det i think but well less torque Report
April 15, 200818 yr comment_239640 F20CInduction Aspirated Power 176kW @ 8300rpm Torque 208Nm @ 7500rpm-7500rpm thats more power than a standerd rb25det i think but well less torque Honda make some pretty mean 4 cyl and there are alot of good parts ex Usa and Japan Report
April 15, 200818 yr comment_239677 good motor but a weak g/box, hell dear and not many replacement parts around. If you want high hp N/A, have a look at the beams motor, i havent seen it done in a ke30 before, they make nearly honda power, are cheaper. more readily available and theres plenty of tough g/boxes that fit. just a thought Report
April 16, 200818 yr comment_239836 Have you considered the NEO SR series nissan engines? The top spec (N1) 1.6L makes 147kW (197hp)! (Pretty sure they run a V-TEC like variable valve timing and lift system) The highest spec 2 litre (SR20VE) has 20 valves and makes over 200hp. Edited April 16, 200818 yr by machg Report
April 17, 200818 yr comment_239947 the F20c will cost you the best part of 10K to buy... you can try a B18 but that a reverse spinning motor and made fo east west... The gearboxes behind the F20c are quite robust, the bits that break are the diffs and axles from abuse. Report
April 17, 200818 yr comment_239960 20 valves in an sr20? you might want to check that type "VVL" into wikipedia or http://www.thecaryard.co.nz/index/Nissan/P...era_232488.html Edited April 17, 200818 yr by machg Report
