Clapped out Posted April 27, 2008 Report Posted April 27, 2008 Hey all, I've just done a search on here and came up with a thousand topics........................... Question- How on earth do i remove all of the sound proofing/body deadening from the floor inside my rolla? i'd be buggered if i'm going to spend two days with a screw driver slowly picking away at it. I've been told that i need to use some sort of heat gun? WTF? Any help would be greatly appreciated! cheers phatke30! Quote
Redwarf Posted April 27, 2008 Report Posted April 27, 2008 (edited) Dry ice apparently is the go. Comes up a treat so I've heard. A heat gun melts it and makes it all gooey = Bad I'm old school: Hammer, chisel, beer, weekend. Edited April 27, 2008 by Redwarf Quote
irokin Posted April 27, 2008 Report Posted April 27, 2008 I use a heat gun and a paint scraper. The job sucks and theres no truly easy way to do it. Basically I try to heat up a big section (say 20cm.sq) and remove it but you need to heat it so that it soaks through to the underside (rather than just heat the top surface). I spend maybe 2-3 minutes heating up the section on low heat (something like 240deg on my gun), then the adhesive goes soft and it just peels off (still takes a fair bit of force). To remove the residue left over I used carby cleaner because it just happened to be nearby but any similar kind of solvent should work. Comes of easy. I do know people who've done it using dry ice but I'm not convinced its any easier (It involves freezing the tar so its hard and smashing it off). Quote
Clapped out Posted April 27, 2008 Author Report Posted April 27, 2008 mmmmmm, the heat gun way sounds rather less time consuming, although getting a hold of a heat gun............i might just buy one. if that doesn't work i'll do redwarf's hammer and grog weekend, thanks for your replies fella's, cheers phatke30! Quote
trd Posted April 27, 2008 Report Posted April 27, 2008 you heat the underside of the floor & the shit should just peel off. Quote
Guest Sbox Posted April 27, 2008 Report Posted April 27, 2008 (edited) Deleted Edited May 24, 2008 by Sbox Quote
WinKE55 Posted April 27, 2008 Report Posted April 27, 2008 I have removed some from falcons. All I was given was a gasket scraper looking thing. And use a hammer haha. Good luck! Quote
Clapped out Posted April 27, 2008 Author Report Posted April 27, 2008 you heat the underside of the floor & the shit should just peel off. and i had to paint the underside of the car before i thought of this :lolcry: If you have access to an air compressor, use an air chisel. You can buy them for stuff all from Super cheap. Only way to fly. I've got one on hand. Thanks, thats another option. I have removed some from falcons. All I was given was a gasket scraper looking thing. And use a hammer haha. Good luck! the tool you use, is it similar to a tile scraper/breaker? Quote
7shades Posted April 27, 2008 Report Posted April 27, 2008 Dry ice, in pellets. Go buy an esky full. It works, I've done it.... But the heat gun works in the areas you can't pile up the ice. Quote
Gribble Posted April 27, 2008 Report Posted April 27, 2008 Dry ice is the go. Worked a treat on the rally-car. If you need to remove sound deadening from more vertical places like the firewall or the sides of the tranny tunnel then get some leather gloves and harden up. Hold it there for a few mins and it works just as well. don't use a heatgun unless you have no braincells left to kill from the fumes or simply can't afford $50 odd bucks for a few kilos of dry ice. Quote
tenyearguarantee Posted April 28, 2008 Report Posted April 28, 2008 my dad has a kings ransom in some kind of bug and tar remover/brake cleaner type stuff. I just did a real lazy ass job with hammer and chisel, then just sprayed it over and over and over again with the cleaning stuff. Probably the most expensive way to do it I also turned slightly pyro and set the shit on fire by pouring kero on it. Works ok, but do it in small sections Quote
Clapped out Posted April 28, 2008 Author Report Posted April 28, 2008 thanks for the idea's guys, dry ice isn't hard for me to get, if it wasn't for moisture somehow makeing its way between the sound deadening (gotta love rust) and the floor i would't have bothered with doing this, i'm going to tackle it this weekend with the idea's in mind, cheers phatke30! Quote
styler Posted April 28, 2008 Report Posted April 28, 2008 yeah dry ice in pellets is the go, i had some pics up on toymods when i did it. use a few bricks as temporary boxing and a plastic bag or a few bags with pellets inside to do diffrent areas and move quickly. also using bags will cover difficult areas very well :lolcry: Quote
irokin Posted April 28, 2008 Report Posted April 28, 2008 don't use a heatgun unless you have no braincells left to kill from the fumes or simply can't afford $50 odd bucks for a few kilos of dry ice. You shouldn't be heating it hot enough to get fumes. No need to go that hot! Once the stuff goes really soft it actually makes it more difficult. Can't say I particularly like the air chisel idea either :lolcry:. Undue haste makes waste! Quote
