Ke30 2 Door Ftw
Why didnt you just drill the lock out on the fuel filler?
Also it needs lowering :jamie:
  • Replies 157
  • Views 108.2k
i tried drilling the lock out yeah, but i snapped 2 drill bits in there..
And yes it does need lowering in the arse,
go dan! go dan!
looking good! looking good!
well it seems my source of parts has informed me he has even MORE of the parts i need, damn bloke is sending me broke HAHA
yeah was weird, i know it did open when i first got it... but i tried everything.. it wouldnt budge..
don't matter, ive sourced a new one :no2:
well,
Got new electric pump in, all works now.
Tried starting car yesty, all it would do would just crank.. no spark, then it started raining so i gave up.
Today i cleaned the plugs, checked leads ect. first crank she started, got to drive it around the yard YAY...
3 probs though
1. Oil leak from the blocking plate i made to cover the hole where the old mechanical pump was...Easy fixed, i made up some new gaskets, and used gasket goop aswell. added extra washer to make sure nut was pressing plate hard enough.
2. Seems my Throw Out bearing int he Box is shot, there is no Whine when out of gear and clutch pedal out, put as soon as i tap the clutch pedal it whines.. Bearing fer sure??
3. Think i may have JUST blown a headgasket.. there was a real small amount of milky stuff under oil cap. BUT, ive also heard the water in radiator goes throfy (spelling)... True?
Apart from that its great, steering is light.... then again I'm Driving a L200 ute as a daily hahah... and boy is the rolla stiff.. :P
Edited by Falken_KE30
2, sure sounds like it. If you're taking the box off, maybe get a new TOB as well as a pilot/spiggot bearing (the one in the end of the crank).
3, I would woirry too much just yet, did you find the condensation after you had it running? Might have just been some moisture in the motor from sitting and you just boiled it out!!!!! :jamie:
Clean out the mayo, and just keep an eye on it for the next week.
Worse case scenario we can get a new HG in for less than $100!!! :P
thanks Si,
Was going to replace TOB anyway, will buy a Spigot bearing too, will get both out and take with me when i buy them..
Yeah it was after running car for bout 10 mins... ill keep an eye on it. i reckon it was moisture, car has been outside last week in the rain.. she back in shed now so all good.
Just gotta find a default sorta setting for the carby and get it running better
Nice car you got there,
ive got a ke30 2 door of my own sittin in the shed. fully stripped right now
working my donkey off gettin it built up. Just doing ot body work on it at the moment and its a massive job, rubbin it all back, its straight though and has no rust in the panels so thats a bonus.
I'm gonna 4age it straight up, the moto is goin so ill have money yaya!! lol
doin to full job on it, motor paint wheels sound interior. can't wait to get it ont he road.
Have ordered a Throw out Bearing, and a spigot bearing.. also got a 1 piece inlet/outlet gasket on order too..
They should be here friday, but i can't pick em up till saturday.. so I'm hoping sunday ill have motor back in and running.. YAY..
2/3 of my rollas have that grill dan. They're just the late ke55e grill.
Yeah don't 4age it,...but saying that what cross member does it have in it, or did Nick just use a stock K cross member?
ive got em lying around as well...
Yeah i realise that now... owell...
Got me one piece inlet/exhaust gasket.. have to pick up the bearings tommorow.
Also, have got my electric pump, and it works.. but for now i just had the power wire going to the fusebox for when the key is turned to the "on" part.
Is there anywire in the boot that i can tap into to get power from?
