4speed Or 5speed That Is The Question.
worth byeing a 5speed for my 5k KE30??
I am not doing anything extreem, just dayly driving.
I havent put the 5k in yet. I have a 3k still, but it sucks trying to do more than 75km/h. Is it because of the obvios lack of power, or the shitty gear box ratio?
Cheers. Doug (adelaide)
have a 5 speed in my KE25 hooked up to the 3K, shitload nicer to drive with the extra gear @ 100km/h :P
t50 on a k motor is not logical unless the motor is worked enough to regularly blow boxes
if you do alot of speeds above 60 on a fairly opten basis then id say its worth it
my ke70 is 4sp n its fair annoying,
if u can find one at u pull it take the shifter out and tell them its a 4spd when u buy it because 4spds are about 80 i think while 5 speeds are almost 200
the only major difference is on a 5 speed ya get overdrive
most of the other ratios will be the same
its not really worth it.
true that the ratios are the same,
if u want shorter ratios get a diff from an auto car
the 5 speed box is slighly weaker.
they have smaller lay gears.
Cheers for all your help people :D
:P I think that was a .....if you want to spend $150 it is worth it....mmm more money
So what cars should i be looking in at the wreckers if i were to want one?
If you do a bit of highway driving, then a 5th gear would be beneficial. Brings down the rpm, therefore use less petrol; it does make quite a difference.
Seems like petrol prices are just going to keep rising, so an investment into a 5 speed would be worth while.
Look for a K50 gearbox out of a KE55.
IIRC this only applies to the KE55 K50 box layshaft bearings, not the gears themselves. The update (KE70?) version K50s have a bigger layshaft than the first (KE55) version.
If you can provide photos otherwise I would be very interested to see them!!
Thanks for all your help gyes.
I am writing this after i have put allot of it in. I forgot i started this thread, and you gyes kept writing.
My bad.
I have found one. At U-pull it. was only $90. Exept when i got it home to mesure it up we realised that the shifter was a bit further back. :D So I sat there and thought about it for a wile. :yes: Dad convinced me to "cut a small nick" into the shifter hole so it would just fit. Exept when we put the box in, we realised that it wouldnt be a "small nick" it would have to be a huge hole :lovin:
So after mesuring it up for a wile i sat there with a hole saw in my hand staring at my rolla. I think i may have said sorry to it and then hacked a hole in the floor. I think i cryed a bit. poor rolla. But it now has a 5K with a 5 speed. so will be allot nicer to drive.
Thanks again for your help :wave: >| :wub: :hug:
Cheers Doug
You have a ke70 k50 by the sounds of then.
Could have avoided cutting the trans tunnel by fitting a ke55 k50 rear extension housing.
Oh well, if what Irokin has written is correct, then you have the stronger of the 2!
this is what i was informed by a toyota mechanic...?
if its incorrect than that fine. but being from a toyota mechanic i would hope its true.
