Sc14 On 4kc
KE70--4KCZ
OK so i started off messing around withe the stock pulley on
the sc14 and have decided to go stupid with a 77mm pulley
and have had a custome crank pulley made. if the calculations
are done right should be pump out 17psi when at 6000rpm ....
MAYBE.... lol
but i need help with what to do about the bottem end any suggestions?
  • Replies 30
I have seen a SC14 run constantly at 14PSI. Soon as it went to 15 it started loosing the Teflon coating on the rotors. This makes the tight seal so I wouldn't push one past 14 PSI my self but to have longevity id go max of about 11 PSI ish
Also 12-13,000 RPM is correct.
Cameron
