hey guy's i have two 5 speed boxes for a k motor at home and i want know whats better....one is a ke55 5 speed and the other box i got told its a celica 5 speed!!
how do i tell whats better????
whats the difference?????
i know one is definately a ke55 5 speed
but i don't if the other one is a celica 5 speed
if you have any info please let me know thanks heaps
cheers shaun..
:yes:
Ok here are some pic's
Thay are both 5 speeds the dirty looking box is on a 3k
and the clean looking box is on a 5k look at where the shifter sits
on the gear box's!!! the gear box on the left i had to cut a hole in the floor
to fit the shifter and the box on the right fit's in the original 4 speed shifter hole
i no thay are 5 speeds can some one tell me what thay are off??? (e.g ke55,ke30 and ke70)
cheers shaun
Edited by shauns ke30
Please try and keep to the english language. Reading that hurt my head.
T50 is celica and wont bolt to your k motor unless you have a K- T bellhousing..
Other is K50 yeah.. bolt to any K motor. only diff in K motor 5 speeds is the KE70 shifter is more towards the rear.. about 10cm back i think
Something would have to be different internally for the shifter position to be further back. But I'm pretty sure that they would be the same ratios.
You only need to change the length of the selector rods to move the shifter position....gears/shafts/bearings etc could all stay the same
As I've done this before, to change the selector position, you only need to swap over the rear extension housing between 5 speed K50's.
4 speed one's wont interchange with the 5 speed variant.
  • 4 weeks later...
EDIT: was wrong my mistake
Travis
Edited by trav_555
not true, i don't think it bolts to a 7k but rest yeah
Travis
Ah no. YOU'RE WRONG.
I have a 7k in my wagon with a regular old K50 behind it.
Yes the 7k block is wider, but the all the K GB patterns are the same.
