T50
they used to be rare, then we discovered new zealand, now just about all good jdm bits are plentiful. my battery brace and washer bottle are from a te27, cos they're all i could find at the time :D
  • Replies 30
  • Views 10k
jamie, te27 bits are rare here too!!!
the easiest way to tell a k40/50 from a t40/50 is the bellhousing.....
does this box have a sperater bellhousing?
if people have an idea on what the k-t bellhousing come sin I'm happy to do some looking.
ok did some looking..... k-t series appears to be in ke74 (5kj) and kt147 (corona)
JDM only so far, there maybe the odd townace etc that has a k-t box.
so they would appear to be rare things! anyone else have any more ideas?
rollin, maybe if you could post some pics up we could help more?
i'm after one of these bellhousings.....
townaces would be where i'd be getting mine from (or warwick)......
never seen or looked at pictures of one though......even if i was to get one of these bellhousings, would it change the rotation of the gearbox?
what about a late townace(sbv) with a 7k in it?
wonder what bell housing that's got on it?
i'll check that out!!
by the way we have a K- T bell housing, and they don't change the rotation of the gearbox, most of the bell housings were hyd clutch but a few are cable, we have a cable one.
if anyone would like a photo just PM me.
Edited by TRD ke70
i thought of the 7k, they use the g series box
so basically you would still have to stand the 4K, 5K, upright before you could attach a t-50 anyway......even using one of those bellhousings....
unless you wanted your shifter in the passengers footwell..... :D
anyone know where or how to make a K50 box stronger....to take more power?
Edited by Xany
Cryo freeze the gears....nitride them...straight cut if your a rich...
they may fail like some of the old RX3 gearboxes did. The housings would flex/crack apart till there was very little of the gears touching and then just strip the gears. Theyd strap the box and then it could hold some 300hp+...
na, you don't have to stand it upright, the bell housing does take the engine angle into account.
Mr Revhead Posted on Apr 9 2005, 03:57 PM
yip your right but toyota on a lot of there engines use the same patten on the bell housing to gearbox.
i have a manual box at work i'll try it out and let you know.
Edited by TRD ke70
don't drop the clutch :D
you can also turn the layshaft around to get a few extra hundred thousand km out of one, as the teeth on one end don't get used so they don't crack
stewart was looking into getting a group buy of billet K gearbox stuff going, but has since decided to put a turbo 4ag into his good sprinter, and then decided to go to japan for 2 years, so don't hold your breath
If you wanted to upright a k series engine using a t series box then to do it properly you need a trd upright bellhousing,but you can run them uprighted without it(gearbox on a lean).From what i`ve seen there isnt that many k series bellhousings around over here some places want $250 for them,the two ive got are 22 spline output shaft boxs and have a hydraulic clutch,one i`ve converted to cable,but ive also got a rare cable operated bellhousing.Easiest way to tell a k from a t series box is as someone said the bellhousings are removable or they`re commonly called split case because they split in half down the centre of the main part of the gearbox,they come in two shifter locations early ta celicas had the forward shifter postion that would suit ke20/30 in fact if you look in the floorpan of a ke 20/30 rearward of the std floorpan mounting bolt holes you`ll see a hole for t series box,and theres the further back shifter postion to suit ke70.T50s also come out in 20 spline and 22 spline output shafts 20 spline fits k series rollas.
cool.......anyone got a k-t bellhousing they wanna sell...... :D
i really need one......breaking gearboxes isnt fun.
blown 5k: what type of gearbox do you have behind yours?.....i'd also be interested to know what diff?
