theres a guy over here in NZ that has a gen3 in his carina race car (n/a tho). ive always stayed away from the 3s cause every rwd one ive seen running rwd (not counting altezza's) has run a bearing, but now i know you can just use a acusump to fix that
dope ride man, i've love to take it for a spin
  • Replies 34
you mean a dry sump setup,
the problem lies in the fact that the standard sump on them is meant to be at an angle, and even then they hold very little oil,
the beams sump holds a fair bit more, is dead flat, has a much better baffle and pickup design and when overfilled shows no obvious reason for failure,
even if oil does pool in the head, which it only really does because of the shear angle the things are at in a fwd setup, in rwd it acts no differently to any other engine
not really a dry sump, more of a pressure valve with resivoir so if you suck up air it keeps feeding oil, big sump should do, mine holds 5L before the oil cooler
a mate of mine has put a gen 3 3sgte into a rav4, and he basically speaks of nothing about oil problems, he basically obsesses with 3s and has built many including 700+hp examples and he rarely talks about oiling issues.
He says the standard block and internals are good for almost 450hp and thats reliable street driven power.
  • 2 months later...
  • 3 months later...
  • 7 months later...
  • 1 year later...
