Hiro Protagonist Posted June 17, 2009 Report Share Posted June 17, 2009 but i seem to only find stuff on here for the 4k? thanks iahn thats my plan would like to tune up te 4ac cos i don't see many of em That's because the RWD 4AC was only found in AE71 and AE86 models here, whereas the K-series is in KE1x, KE2x, KE3x/55 and KE70s, so simple maths should tell you why you see more about 4Ks than 4ACs on Rollaclub.... Quote Link to comment Share on other sites More sharing options...
benzo Posted June 17, 2009 Report Share Posted June 17, 2009 I have no idea why you'd wanna rip out the 4ac and replace it with a 4k. I'd stick with the 4ac, they're a good engine, much better than most people give them credit for. Cheers, Ben. Quote Link to comment Share on other sites More sharing options...
philbey Posted June 17, 2009 Report Share Posted June 17, 2009 Plus the fact that it's fairly straightforward to swap a 4AGE into a 4AC car, whereas a 4K would require more effort! Performance bits for the 4AC aren't particularly common - I don't even think there is an off the shelf sidedraft manifold for them, the only ones I've seen are custom fabricated. Quote Link to comment Share on other sites More sharing options...
ae71piggie Posted June 17, 2009 Author Report Share Posted June 17, 2009 thanks for all your help guys found out what i needed the 4ac will be staying in the car and i will be modding it well trying to thanks ae pig Quote Link to comment Share on other sites More sharing options...
benzo Posted June 17, 2009 Report Share Posted June 17, 2009 Plus the fact that it's fairly straightforward to swap a 4AGE into a 4AC car, whereas a 4K would require more effort! Performance bits for the 4AC aren't particularly common - I don't even think there is an off the shelf sidedraft manifold for them, the only ones I've seen are custom fabricated. exact 4AC's do not have the strongest aftermarket support but even with just a 32/36 weber and free flowing 2-inch exhaust they get going pretty well. I have driven a mates stock 4AC which went just as good as most stock 4AGE's go Cheers, Ben. Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted June 17, 2009 Report Share Posted June 17, 2009 Performance bits for the 4AC aren't particularly common - I don't even think there is an off the shelf sidedraft manifold for them, the only ones I've seen are custom fabricated. Probably linked to the fact that a lot of 4ACs are FWD-spec (in AE82s), thus making a sidedraught a bit hard to install.....4AGEs are common enough for RWD swaps that there is a market for them though, and all K-series are RWD thus making it easier for sidedraughts. Quote Link to comment Share on other sites More sharing options...
ae71piggie Posted June 17, 2009 Author Report Share Posted June 17, 2009 thanks mate the 4ac will be staying in there untill i get some decent cash behind me then tempted on ca18det or even sr hahah who knows but starting with this.... first thing i need is a f@$king water pump ae pig Quote Link to comment Share on other sites More sharing options...
toms.AE71 Posted June 19, 2009 Report Share Posted June 19, 2009 go for a supercharged 4ac, i was gonna do mine till i bought another car. was gonna be cheap aswell under 600 buks for 120+ kw at rear wheels Quote Link to comment Share on other sites More sharing options...
benzo Posted June 19, 2009 Report Share Posted June 19, 2009 go for a supercharged 4ac, i was gonna do mine till i bought another car.was gonna be cheap aswell under 600 buks for 120+ kw at rear wheels Where did you 120rwkw from? Would like to see how long a $600 supercharged 4AC would last Could've been good lol Quote Link to comment Share on other sites More sharing options...
kiahn Posted June 19, 2009 Report Share Posted June 19, 2009 why bother super charging it?? you could easily get a small turbo and run it at 6 or 7 psi and it sounds better when it spools too, if you wanted to do a different conversion you could get something like a 3tgte and fit it in would be quite a nice amount of power 2 weight from that Quote Link to comment Share on other sites More sharing options...
hilux05 Posted June 19, 2009 Report Share Posted June 19, 2009 HKS did do a few side draught mani's for the good ol 4ac, one was for sale on DC a late last year too... As what tom said. Blow thru supercharged is what i intended to do to mine but of course a 4ag came up at a price i literely couldn't say no to.. but if you want some idaes.. http://www.paradiseracing.com/index.htm http://4ac-powered.forumotion.com/forum.htm the best 4ac site.. Richie. Quote Link to comment Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted June 22, 2009 Report Share Posted June 22, 2009 ive just got myself a 4ac ae-71 for freethinking of puttig a 4k or even 5k in it wanting to keep with the corolla eingines as i don't mind em what u guys think are the best engines and why and wats best to mod thanks ae pig I would not bother going to a 4K as it is a 1.3lt and the 4AC is a 1.6lt. Also people have said the 4AC has the same Block as the 4AGE so it is just a straight Head swap. I would say stick to the 4AC and/or upgrade in the future. Cool! Quote Link to comment Share on other sites More sharing options...
KE70-from-mt-panorama Posted June 22, 2009 Report Share Posted June 22, 2009 I would not bother going to a 4K as it is a 1.3lt and the 4AC is a 1.6lt. Also people have said the 4AC has the same Block as the 4AGE so it is just a straight Head swap. I would say stick to the 4AC and/or upgrade in the future. Cool! Same block, Has different crank though. Has a 6 bolt flywheel where the 4age is 8 bolt. You can get away with a simple head swap, But i would use a 4age bottom end as i know it is suited to rev to nearly 8000rpm stock. Not sure about the 4ac conrods being the same, but the pistons are different aswell. The 4ac one don't have cutouts for the valves in them, Making it an interferance motor which could be costly in the event of a timing belt failure. IMO most people don't work with the 4ac because it is so easy to put a 4age in. It uses the same mounting, same gearbox. So if you have a car with a 4ac in it already its just easy to put a 4age in it, and if your converting a k-series car to a-series its as much work to get a 4ac in there as it is to do a 4age, so people put in the extra effort and extra cost for the extra power, and performance support. Quote Link to comment Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted June 22, 2009 Report Share Posted June 22, 2009 Same block, Has different crank though. Has a 6 bolt flywheel where the 4age is 8 bolt. You can get away with a simple head swap, But i would use a 4age bottom end as i know it is suited to rev to nearly 8000rpm stock. Not sure about the 4ac conrods being the same, but the pistons are different aswell. The 4ac one don't have cutouts for the valves in them, Making it an interferance motor which could be costly in the event of a timing belt failure. IMO most people don't work with the 4ac because it is so easy to put a 4age in. It uses the same mounting, same gearbox. So if you have a car with a 4ac in it already its just easy to put a 4age in it, and if your converting a k-series car to a-series its as much work to get a 4ac in there as it is to do a 4age, so people put in the extra effort and extra cost for the extra power, and performance support. Yeah for sure man! Thanks for that, leant something new. Like you said the 4AC and the 4AGE have the same engine and gearbox mountings it saves a hell of a lot time. So I guess best off going the full conversion. Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted June 22, 2009 Report Share Posted June 22, 2009 go for a supercharged 4ac, i was gonna do mine till i bought another car.was gonna be cheap aswell under 600 buks for 120+ kw at rear wheels Who's your dealer? That's some major-strength ganga you're smoking if you think $600 spent on supercharging a 4AC will give you 120kw at the rear wheels, hell a standard healthy 4AGZE struggles to get 90-100 at the wheels in a FWD car, and RWD will give you more losses, plus you're starting from a 4AC.... Quote Link to comment Share on other sites More sharing options...
