1jz Ke55
1JZKe55
After a few more hours of work on the rolla today I have finally got all the rear brake lines made and fitted and plumbed up the wildwood brake proportioning valve as well as the handbrake now i'm just waiting on the new master cylinder to turn up then it should have some brakes :yes:
  • Upvote 1
I've put a couple extra bits into the cage clutch and brake master cylinder are both mounted after some stuffing around had to put the clutch master under the dash which caused issues in its self with the lack of room to run the line thank god for my new plasma cutter :lol:
After the last couple of weeks working on the rolla the list of things to do is finally getting smaller I can see the light at the end of the tunnel :greenbounce: so today I thought I'd tackle the worst of the rust the in right rear quarter we had another quarter panel that we thought was good but someone had done a really shit rust repair on it and filled it with bog so ill be making a replacement peace for the bottom of the quarter
