My 2T-B engine is seriously leaking oil, about 1 litre a day, the starter is dead, and many other problems
so I've decided to move all the parts from the ae86 ( 170hp 4age, big front brakes, coilovers suspension, hydraulic handbrake, rear axle with limited slip and rollcage if it fits )
so therefore I have some questions that might already been answered, but I couldn't find it.
ae86 parts, ke70 car
engine, front suspension, steering components, crossmember = bolt on
gearbox and gearbox crossmember = bolt on
tailshaft = bolt on or does it need to be shortened?
rear axle = bolt on
fuel tank with built-in pump = same size, so I'll guess it will fit? anyone done this before? what should I do about the wiring to the fuel pump?
fuel lines, return line and brake lines = I guess I could use my old brake lines at front, but what about the rear? And what about the fuel lines, my old wouldn't be thick enough I guess?
and the EFI ( CRAP ), everything in the ae86 is working, so I just hope it isn't very much cables not from the engine that goes to the EFI is it?
exhaust will fit without much trouble I guess..
I guess that is about all..
any comments, questions or ideas will be apriciated
I originaly planed to be finished within a month or so, but now I'm really in a hurry because my 2T-B engine is dead :\, so I plan to atleast take everything out of the ae86 this weekend,
maybe even be finished, I just don't know how many hours of work this will take me
and yes, I will take pictures :)
Edited by David
  • Replies 242
it's nothing wrong with the ae86 except it's 3 times more expenssive insurance
than the ke70... the ke70 is also in much better shape than the ae86, ( rust )
and I have to pay waaaaaay to much money to get license plates on it, and I won't risk weld on the ke70 chassi number on the ae86...
the ke70 is also a lighter car, so it will go faster :)
I also think it's nice to have a real sleeper, instead of a car everybody want to steal..
Edited by David
gotcha.
ok when i did the efi in daisy, i ran the fuel return line back to the tank using the charcoal canister vapor line. (don't know what kind of emissions equipment you guys have). the wiring harness was easy; the 1983 starlet efi was a factory add-on, i just snatched the efi harness, wired up the main relay, hooked up +12v, ign, start, ground, and a/c.
i used the in-line starlet fuel pump, but i don't know how well my feed is as the line is so small and THERE IS NO SUMP; i go around corners hard with less than 1/4 tank and it will starve.
i don't know much about the later corollas, but i don't see why the rear axle wont fit.
hmm...
I need to know exactly what to do with the EFI wiring thingy
do I only need to connect everything from the engine to the EFI, and then connect + and ground to the third plug on the EFI? or is it more? if so, tell me now! :) else I will just scratch my head all weekend and not getting finished before monday
yeah, great, I will move everything over to the ke70
does anybody know if the dashboard fits or could be fitted in a simple way?
or do you guys just think it'll look stupid?
( I want builtin tachometer ) :)
okay, maybe 'carpet' it, using some sort of carpet for subwoofer box, I think that will look great :)
but as demuire said, change the whole loom.. I've just used 30 to 1 hour comparing the two cars.
things like dash, lights, etc won't fit, because of different plugs.. what should I do about that?
and changing the whole loom, is that the whole loom, including fuse boxes, etc?
I think that's alot of work with no gain what so ever..?
correct me if i'm wrong but I just don't see the point when acording to club4ag I can just connect the engine loom to the ecu, connect 3-5 cables from my old main loom to the ecu and that's it?
wiring diagram
also: do you have any ideas of where I could mount the ECU? it doesn't seem to be enough space where it is in the ae86..
maybe only put it in the glovebox?
Edited by David
i mounted my ecu upright (like a book in a bookshelf) in between the fuse panel and the steering column....but mine left hand drive.....
Edited by mikeys toy
okay hehe, ( mine is also left hand drive )
who wants spagetti for dinner?
this is on the engine loom, connected to the main loom.. do I need this to run the engine? if so, what should I connect it to?
or is it impossible to run the engine without the main loom?
what is this? it's on the ECU.. do I need to connect it to make the engine run?
If it's what I think it is, you will need it to tune the car properly. To set timing on an A engine, the idle needs to be slightly higher, and I believe that by shorting two of those connections, that's what it will achieve. Be safe, leave it in... :)
R
(Here endth my A engine knowledge.)
Rob: Remember when I was trying to set the timing on my car? Shorting the terminals didn't really do anything :)
David: My computer doesn't have that, so no idea. Looks like you have your work cut out for you! Sorry I couldn't be of much help, my car didn't have any of the bits yours has!
Now I've been working all weekend, and taken alot of pictures, but of course I forgot the camera, so I will post them later this week
the ke70 has now:
4A-GE with 170hp
T50
Coilovers with stiff springs and bilstein shocks at front
Big brakes at front, with vented cross drilled discs
ae86 discs brakes at rear
Quaife quick ratio steering ( about
Longer control arms
ae86 rear axle with LSD ( it may need to be reconditioned sometime in the near future )
stiffer springs and bilstein shocks at rear..
The tailshaft is not yet mounted and the electrical system is untouched, so I will soon be finished with the conversion :thumbsup:
