December 14, 200916 yr Author comment_398173 sounds like i might just have to strip down the carb, and check my ignition system. Report
December 15, 200916 yr comment_398319 For the money involved I would suggest you replace everything in the ignition system just to be sure. At the least it won't hurt. Get new Points, condensor, rotor button, dist cap, and plugs for a start. Don't forget the condensor, lots of people over look them because they seem like they don't do much, but your points will get eaten away with out one and if the one you have isn't doing it's job correctly the same fate will await your new points. If doing this proves no improvement replace leads. Still no improvement, start on the carb. You may be able to get away with simply cleaning and adjusting the points. It is something that needs to be checked and adjusted at least every 5000k for happy performance. However, for the maybe $100 (TOPS) all the brand new ignition parts will cost you, I suggest you just do it right the first time or else you end up chasing your tail. Matt Report
December 15, 200916 yr comment_398327 i belieive timing on a 4k is 8 degrees defore top dead center, and the points and plug gaps are .8 of a millimeter, 10 degrees will probly work but 15 on a standerd 4k definately will not. Just to rule it out, jack up the back of the car and put it in neutral with handbrake off, your brakes cylinders might be slow to release, sounds stupid but its happened to my ke70 on one side, you could do the front as well. Report
December 15, 200916 yr Author comment_398331 ok guys. thats enough. i think i have about 4 weekends of checking stuff! So much for my quick fix. thanks all. how about i just drop a 4age in it while I'm at it? ha ha. Report
December 15, 200916 yr comment_398332 i belieive timing on a 4k is 8 degrees defore top dead center, and the points and plug gaps are .8 of a millimeter, 10 degrees will probly work but 15 on a standerd 4k definately will not. Just to rule it out, jack up the back of the car and put it in neutral with handbrake off, your brakes cylinders might be slow to release, sounds stupid but its happened to my ke70 on one side, you could do the front as well. BULL f@$kING SHIT! my 4kc on 10degrees chewed through fuel, went no where, just a absolute PIG, bumped it up to 15 and noticed the difference STRAIGHT away, doubled the fuel economy, does bigger skids in the same sitiation where 10degrees didnt and doesnt idle like a rotary Report
December 17, 200916 yr comment_398861 BULL f@$kING SHIT! my 4kc on 10degrees chewed through fuel, went no where, just a absolute PIG, bumped it up to 15 and noticed the difference STRAIGHT away, doubled the fuel economy, does bigger skids in the same sitiation where 10degrees didnt and doesnt idle like a rotary I'm just giving him the information from underneath the bonnet of a stock standard ke70 4k engine, STOCK. its written on the label. Report
December 17, 200916 yr comment_398862 Yeah but I bet the sticker doesn't say "15* won't work"!? Evan is correct in stating this is bs. :locked: i might just take it to a mechanic. That might be a good idea. :n: Edited December 17, 200916 yr by Taz_Rx Report
December 17, 200916 yr comment_398972 Spark plug gap: 0.8mm Contact Breaker gap: 0.45mm Dwell: 46deg Timing at idle: 8 deg btdc No offense, but people should reference things before posting stuff like this Report
January 8, 201016 yr Author comment_403861 my manual says for flat spots on acceleration *faulty accelerator pump linkage: Check and rectify pump linkage *faulty accelerator pump plunger cup: renew pump plunger There are NO diagrams so i have no idea what to rectify renew. Read the whole carby bit of the manual and still can't find a diagram showing this part. If you could point me towards what it is or a photo i would appreciate it. Report
January 8, 201016 yr comment_403912 should be on top of your carby mate. take the whole airfilter assembly off and have a look at the links. one should go up to top of carby and it pushs a plunger down. thats your accelerator pump, i drops a blob of fuel in to compensate for the sudden change in air been sucked in by pressing the throttle. If its sticky, or the bit the fuel comes out is clogged, it wont function properly and youll get the problems your having now. i replaced mine and set it according to the Toyota K motor Yellow manual and bam, havnt had a problem since. Good luck, will snap some pic tomorrow if i remember :lolcry: Report
January 8, 201016 yr Author comment_403916 sweet cheers mate ill check it out, is this something i can pick up at repco? Or will i need to order it in from a toyota parts place. Ive been surfing the web for ages trying to find some pics, doesnt help ive been throttled back to 32kb/s. Report
January 8, 201016 yr comment_403922 not sure mate, i had 3 carbies to make one good one LOL, one carby had new gaskets and some other bits, but not a new accelerator pump, and the lower shaft was worn so it would leak fuel. Ill grab a pic of it tomorrow Report
January 8, 201016 yr comment_403926 Simple. accelerator pump in the carb. If the pump is U.S. the carb will eventually catch up. This is 1st year apprentice problem solving. good luck ask more questions if required. U.S. = unserviceable Report
January 8, 201016 yr comment_403931 I'm just giving him the information from underneath the bonnet of a stock standard ke70 4k engine, STOCK. its written on the label. yep says the same thing in my manual, it also says 91 octane i ran shell v power on 8 degrees and it ran like a old 3 legged pig, so after a couple of days i tried bumping the timing up to 15 degrees and taking it around the block. i did that a felt a difference so i left it there. but i was running 91 on 8 degrees for a couple of days, it was pinging/ detonating you name it Edited January 8, 201016 yr by Evan G Report
