October 24, 200521 yr comment_78756 I sussed this out for the first time, as Nick put this up in the Thread of the year section... and I CAN SEE WHY!!!!!! WORK OF ART, Banjo!!! :D *Tiger stamps 2 paws of approval* Report
October 24, 200521 yr comment_78767 mine will be eventually finished.....its mainly just the attachments i have to do now....the hard part is done. :( havent had much time in the last month or so to do anything at home.... :D Report
February 9, 200620 yr comment_100639 So what happened to your work guys? This thread has fizzled. Necro +1. Report
February 9, 200620 yr comment_100701 mine is kinda put on hold......i'll get it finished in the near future.....trust me. :D i might have a bit of time to work on it this weekend actually :o Report
February 10, 200620 yr comment_101045 what about banjo, i read this thread back when i was newb, it makes more sense now, and i want all to be revealed :o Report
June 25, 200620 yr comment_125151 well......i thought i'd dig this up now that i've actually completed the stand and have an engine and gearbox sitting on it properly.....its a bit more primative to banjos, but its all still there...lol... i'll get piccys up sometime this week. Report
June 25, 200620 yr comment_125208 I want to know how the engine ran. You normaly don't put the magnets into steel as it spreads the magnetic field,so it wont be as pinpointed, you normaly put them into aluminium. Are the magnets raised above the surface, If it does work ok id like to try it myself. Report
June 26, 200620 yr comment_125396 well i figured out the bug that was in my system, and EEEEETTTS ALIVE!!!! The 5K i have on the stand atm roared to life at about 8:30 tonight....with no exhaust i might add....lol So next is hooking up the gauges i have sitting here and then running the engine for a bit :) Report
June 26, 200620 yr comment_125397 noice!! gotta see some pics! did u get flammage out the lack of exhaust? :) so is it an actual dyno ? Report
June 26, 200620 yr comment_125401 Atm its just a test stand....it may turn into a dyno if i can figure out how to hook something to the output of the engine... :) The engine hasnt actually run long enough for anything to heat up, there for no flammage....(didnt wanna piss off the neighbours with the noise) Report
June 26, 200620 yr comment_125409 soft! ahaha i wanna see flamage vids! can't u do the whole drum brake to the crank and blah blah like old school engine dynos remember readin somethin bout it once Report
June 27, 200620 yr comment_125586 Grab a hydraulic PTO off a digger or something. Hook up a valve to control the load and an oil cooler to stop things getting real hot, real fast and away you go. Variable load dyno :) Report
June 27, 200620 yr comment_125606 This is great! I think that I'll be grabbing the crossmember off my KE55 before it goes to scrap, I'm taking from the pictures at the start of the thread that there is only four bolts holding it on? Cheers, Dan. Report
June 27, 200620 yr comment_125640 Correct...make up a frame and hook up some electrics and away you go... The 5K i have only just got running hasnt been started for about 18months....and it basically started first go, with some choke and a bit of cranking....who said k motors werent reliable.. lol... Report
July 2, 200620 yr comment_126374 Alright, thats it; I'm going outside to take the crossmember off; back soon people :dance: Report
