August 1, 201016 yr comment_456069 The actual weight is not completely relevent, the weights of vehicles are listed in the qld modifications book, not sure of the exact name.... this is what most engineers use, as almost every vehicle is listed in that book with a set weight beside it. see an engineer, and if hes too busy, just ask for his book to have a read of, then you have a definate answer at least... Report
August 1, 201016 yr comment_456106 The actual weight is not completely relevent, the weights of vehicles are listed in the qld modifications book, not sure of the exact name.... this is what most engineers use, as almost every vehicle is listed in that book with a set weight beside it. see an engineer, and if hes too busy, just ask for his book to have a read of, then you have a definate answer at least... Is this the same number as on the rego papers? Report
August 1, 201016 yr comment_456152 Not sure if nsw is the same, we don't have weights on our normal vehicle rego papers in qld. Report
August 3, 201016 yr comment_456765 In Vic that weight is the Tare weight on the rego and so is act. Wouldnt know about anywhere else Report
August 4, 201016 yr comment_456801 http://www.redbook.com.au/used-cars/detail...id=12A3D6ADE6DC Redbook says 930. Do the engineers go off dry toyota weights or current weights when presented by the owner trying to engineer. Edited August 4, 201016 yr by cuzzo Report
August 4, 201016 yr comment_456803 http://www.redbook.com.au/used-cars/detail...id=12A3D6ADE6DC Redbook says 930. Do the engineers go off dry toyota weights or current weights when presented by the owner trying to engineer. And I would not take that into account, redbook weights have been known to be incorrect. Report
August 4, 201016 yr comment_456805 And I would not take that into account, redbook weights have been known to be incorrect. Ahh poo, i would have thought a site like that would be accurate....still looking. Report
August 4, 201016 yr comment_456904 3rz n/a is legal 3rz +turbo is not rego with 3rz THEN add hairdryer ..... hope not to be pulled over Report
August 4, 201016 yr comment_456955 just get the mod plate guy to add the turbo code onto the blueplate :( Report
February 9, 201313 yr comment_646810 so how did you go with this conversion, anyone know what the difference between ae71 and ke cross members? Report
February 9, 201313 yr comment_646822 well with the new ncop we have in qld, this conversion is legal. new category of weight 800kg - 1100kg is now vehicle weight x 2.75 for turbo cars. So if anyone is thinking about doing this, it is very possible. Report
February 10, 201313 yr comment_646933 so how did you go with this conversion, anyone know what the difference between ae71 and ke cross members? the engine mounts sit up higher on the K series mounts Report
