May 25, 201214 yr comment_606017 Anyone done a front setup in a ke30? Like a cheaper option then coilover kits andwhat not. Corona or ke70 struts, stiff springs, and lca 60mm longer or there abouts. Am I on the right track,? What on earth do you need 60mm longer lca's for? 20mm maybe.. Weld the diff. Stiffen the leafs or turn them over if it's a track only car. Shorten your steering arms or get someone to do it for you. Not sure if ke30's have lock stops or not.. Report
May 25, 201214 yr comment_606022 i think there is alot of emphasis on buying stuff to make your car drift. Best of getting out there and practising. in the words of a famous dodgeball coach: 'if you can dodge a wrench you can dodge a dodgeball' (disclaimer: there = on a track, dodge = drift, wrench = combi van, dodgeball = drift car) Edited May 25, 201214 yr by ke70dave Report
May 25, 201214 yr comment_606026 Best off getting out there and practising. "There" being a track, obviously. Report
May 25, 201214 yr comment_606032 "There" being a track, obviously. Or a rally road... which would of course be made on private land and with the owners consent of course, :rolls: . Report
May 25, 201214 yr comment_606069 I'm not worrying about learning to drift I just wana set it up stiffer. We have a rally ke30 and contlstantly 3rd gear flat lock to lock fishys is good practice haha. Even more fun when the 2 rear tyres are shredded. Report
May 25, 201214 yr comment_606176 i think there is alot of emphasis on buying stuff to make your car drift. Best of getting out there and practising. in the words of a famous tofu shop owner; "The 86 trains the driver." Report
November 18, 201214 yr comment_636844 Revive mofo's! I'm getting a wheel alignment this week these are the specs I'm thinking.: +2mm toe out overal (1mm per side) -3.5 camber or there abouts essential just even up what I have now. Max positive caster? Is that correct Any issues with that or recommendations. EDIT: oh the cars a KE70 if you didn't know Edited November 18, 201214 yr by It's_AUDM_Yo Report
November 18, 201214 yr comment_636902 I was running -2.5 degrees camber and 1mm toe out each side. Skidded fine. I reckon start low on everything and if you think you need more then go for another alignment.a No clue on castor. Running the 86 tops so more negative castor? haha I think if you're going to daily it, the toe out might not be too nice on your tyres. Report
November 18, 201214 yr comment_636915 yeah those numbers are quite extreme... id start with: -zero toe -around 4 to 5 deg + castor -1.5 deg camber. Thats a fair amount of castor so will give you heaps of camber when you turn the wheel anyway. Too much castor makes the car UBER twitchy at high speed, and too much camber gives you less grip in a straight line especially in the wet! Report
November 19, 201214 yr comment_636925 I'll go easier on the toe and caster. Apparently the max caster you can get with the stock units is about 3-3.5 so I won't really have that much. I can't really have any less camber if you look at photos I have ~2inches of tyre in the guard Report
November 19, 201214 yr comment_636993 My car performed well mid corner with the settings I mentioned above. But I had never driven it with all that gear in it before so it was hard to notice anything different other than the stiffness. If you can I reckon get the camber down as much as possible. Report
November 19, 201214 yr comment_636998 Yeah I'm aiming to get the camber down, hopefully a bit more castor will help the scrubbing near lock. But yeah I'm sure it will take a few different setups before I decide what I like. Just want to get it pretty reasonable to start with. Next set of front tyres will be 55s and that should pretty much stop all the rubbing. Report
November 19, 201214 yr comment_637038 Niiiice. I'm keen for a cruise soon. Should have the white car on the road within a few weeks so I'm going to try and get a few cars/people to go for a drive with. Report
