1) Knowledge Base/FAQ
2) Search
3) Google
4) ???
5) Profit?
1.The FAQ does not have valve sizes in the head section.
2. Could not find anything that mentions valves for a K motor searching "valve size"
3. After googling, I found this:
http://www.toymods.org.au/forums/showthread.php?t=4365
valves, rockers, rocker shafts and rocke towers will change between the different heads.
If it had been covered better I would see it as being a waste of a thread but since there is SFA on it give him a break.
From memory, early K heads : Big ports, small valves, then it went to big port bigger valves, and from that point they're all pretty much the same.
No real difference after the early K's.
+1 :rolls:
Thanks matee :rolls: big helpp hey by any chance would you no from what year the bigport heads with bigger valves came out??
Thanks heaps again
Thanks heaps again
The first 3k's around 1969 or so in the ke11/17/18 through the ke2x series.
