November 1, 201016 yr comment_479436 hi am wanting to know if there is another dash that will fit into a ke30 2dr or if there is a tilt steering column that would fit? Report
November 1, 201016 yr comment_479465 You can swap to a ke55 style dash in a ke30 but its a whole lot more work than I would care the think about. Honestly a custom dash would be easier. Trying to convert the steering column to tilt would be about as easy as converting the rear suspension to coils. Report
November 1, 201016 yr comment_479478 Trying to convert the steering column to tilt would be about as easy as converting the rear suspension to coils. bahaha! Report
November 5, 201016 yr Author comment_480408 so can it be done or not or are you being sarcastic... Report
November 5, 201016 yr comment_480420 Anything can be done. With enough cash, time and angle grinders ;) Report
November 6, 201016 yr Author comment_480428 yeh thats true but would i have to use a different steering column and from which car if anyone knows? Report
November 6, 201016 yr comment_480433 You can swap to a ke55 style dash in a ke30 but its a whole lot more work than I would care the think about. Honestly a custom dash would be easier. Trying to convert the steering column to tilt would be about as easy as converting the rear suspension to coils. I'm looking into doing this conversion. I've bought an overseas SR5 dash cluster to go with the rest of it. What troubles are there fitting it? Report
November 6, 201016 yr comment_480588 To remove the whole dash its just a right prock of a job. There's bolts and screws you just can't get at that make life very difficult. The last car I removed a dash from was being wrecked so we just started getting aggressive with it and litterally tearing stuff out. :glare: Report
February 25, 201115 yr comment_505658 To remove the whole dash its just a right prock of a job. There's bolts and screws you just can't get at that make life very difficult. The last car I removed a dash from was being wrecked so we just started getting aggressive with it and litterally tearing stuff out. :glare: really i just pulled the dash out of my ke30 and it only took half an hour with nothing broken does anyone have a replacement ke30 dash that i could buy the one i just pulled out has sun damage Report
February 25, 201115 yr comment_505662 really i just pulled the dash out of my ke30 and it only took half an hour with nothing broken does anyone have a replacement ke30 dash that i could buy the one i just pulled out has sun damage yeah my dash from my ke35 is badly sun damaged to since i can't find another dash like it (its the old jap style) \ i was thinking to take it to a dash place to get it re wrapped in vinyl or whatever that material may be Report
February 25, 201115 yr comment_505671 ra65's had steering tilt adjust, you might get lucky with it being close enough to a ke70 to do something about Report
February 25, 201115 yr comment_505805 yeah my dash from my ke35 is badly sun damaged to since i can't find another dash like it (its the old jap style) \ i was thinking to take it to a dash place to get it re wrapped in vinyl or whatever that material may be yeah that is prob the best way to go ive seen a few adds with people selling a dash but ive had no reply, so i might have to pull my dash out of the dump pile and just go and get it repaired Report
July 2, 201115 yr comment_536797 in regards to the tilt steering column... I worked with mechanic that told me he fitted a tilt column and it was either a toyota avensis or a kia carnval, did need to cut and weld and manufacture a shite load but he ended up with a steering column that tilted and extended in and out too!!!! I'll try and ask more people and see what I can find out. Just go to a rollaclub meet and ask the ioldest person there, usually they're more than happy to tell you how to "modernise" you lovely rolla... :P Report
July 5, 201115 yr comment_537518 really i just pulled the dash out of my ke30 and it only took half an hour with nothing broken does anyone have a replacement ke30 dash that i could buy the one i just pulled out has sun damage Dash resto guy on the gold coast did mine, cost and arm and a leg, worth it tho Mine only takes 10 mins to take out, including the S13 cluster and guages and i have the roll cage in their, possibly i have mine mounted differently, I'm not sure why you want an adjustable steering, perhaps height??? the KE30 Two Door dash is a work of art IMO and has endless options to setup guages or clusters, otherwise, cut and shut a S13 silvia dash and centre console, make your own brackets, patience and skill would be needed Report
November 22, 201411 yr comment_691020 Hello . does someone knows if the dashboard of the 4door corolla mod 1977 can fit to corolla 2door 1976 because the newest one is divided and the one my car wears was one piece .Thanks . Report
