Introducing Lexi (yeah I know, original, but I didn't choose it), Cara's first turbo car, and also her first car which is noticeably faster and better than mine :P. Looks like I'll have to tread the family car route in a few years then, maybe something like a Chaser for the practicality as well as the speed, can't let her out-do me can I? Anyway, I digress.......
Specs: AS OF 09/08/13
1995 (build) JZZ30 Toyota Soarer GT-T (thought it was a GT-TL, but the build plate says otherwise)
Engine-related
1JZ-GTE twin-turbo
APEXi Power FC + hand-controller
Front-mount Hybrid dual-core intercooler
K&N pod BFI in sealed box, custom alloy intake pipe
Lews split dump pipes with separate wastegate pipes, split twin 2 1/2" stainless mandrel exhaust with two twin-tip Lukey mufflers
Suspension/driveline
R154 5-speed factory manual
HKS HipermaxII adjustable coilovers
Polished alloy strut-brace
KAAZ 2-way mechanical LSD
DBA 4000 Clubspec slotted rotors front, DBA 3000 slotted rear
EBC Redstuff brake pads f+r
TRD leather gear knob
Exterior
18x8" Speedy Cheetah wheels
235/40 Kumho KU39 Le Sport
Interior
Tan interior, velour
Electric seats
Sunroof
Flip-out cupholder
Scroll dash, blue filtered
Refurbished climate control screen w/ blue button lights
ICE
Kenwood DNX5360 2DIN DVD/GPS receiver
Audison Bit One processor
JL Audio 2.1 amp
Front Morel splits in custom door trims
Rear Morel speakers
12" Treo Sub in a moulded box in the boot
Entire cabin + boot Dynamat'ed except for roof
Mongoose alarm/immobiliser
Waiting to be installed:
HKS adjustable cam gears
Future list of mods/fixes:
Paint
Re-leather steering wheel
New bushes
Paint cam covers
New cams (a while off now)
Photos:
Looks like it has two black holes for wheels...
Mid-life taillights are the best of the bunch
Can see some of the phat-ness of the rear tyres there
Plates are like that because previous owner's mate had a HQ with a worked 202, so he did what any self-respecting Toyota owner would do
Neat boot install. Amp is tucked up underneath parcel shelf where stock sub would sit, completely out of site
Interior is interior
It's a headunit
No wait, it's a DVD player!
Custom door pods...well entire bottom section of door-trim is custom actually...
Engine-bay is engine-bay
Except for extensive earth kit
Current insurance policy.
Edited by Hiro Protagonist
  • Replies 55
manual soarass not many around at all
lucky girl and it's even harder to find a woman who knows how to drive a manwell too :P
O_____O this is what i dream of owning aswell as a supra :groupwave: :wootjump: :groupwave: :wootjump: :groupwave: :wootjump: :groupwave: :wootjump: :groupwave: :wootjump: :bounce: CAN I HAVE IT PLZ btw great car
Well, I _did_ teach her how to drive manual...
Anyhoo, ran the Soarer at last weekend's Toymods Dyno Day, unfortunately didn't quite live up to the 200kw claim but still quite respectable, conditions were far from perfect and there is still plenty of room to play with mod-wise and still keep it looking stockish
Previous run at SAS in same tune but in much more favourable conditions :P
Driving to work this morning and coming to the realisation that the clutch in the Soarer seems to be on the way out.....normal around-town gearchanges are fine, but if you punt it in gear it'll flare like an auto, especially when you're hitting or in boost. Worse too if it is part throttle, as you can get it to flare a good 2-3000rpm (combined with a lovely smell), whereas full throttle gives you enough power through to the wheels for them to catch up to the revs and stop the slipping.
Anyone got recommendations for a good street-suitable girl-suitable clutch for a 1JZ/R154 that can handle 250-odd kw? As far as I can tell it is still running the factory clutch, something a little heavier wouldn't be a problem (it is lighter than the factory clutch in the AE102, somehow), but don't want to splurge on a twin-plate or anything exotic if possible.
If you still want it streetable, i'd be suggesting a heavy duty clutch and thats about it.
It should operate with a 50% increase in clamping force over the factory item.
Just remember, there are two types of clutch, push and pull and going by my clutch book here, it is a pull type.
Extreme Clutch Part No. - KTY24009HD
Hope that helps :)
Hope that helps :)
Thanks, definitely has to remain streetable as it is Cara's daily, but it would also see the odd 1/4 and the outside chance of a track-day or two. Power figures shouldn't grow too much so I'd expect a max of 300kw at the fly before I'd be thinking serious upgrade.
Might be a good time to go for a lighter flywheel too, stock one seems fairly heavy and revs take a while to settle (although that could be PowerFC-related too...)
Well, the drama of the banana-peel-instead-of-a-clutch has been rectified, although at significant pain to the hip pocket. What was initially quoted to be a $700 clutch from the Exedy distributor turned into a $1200 clutch, plus add on about $800 in parts and labour. Still, being able to plant it with confidence makes it worthwhile, it was getting to the stage where it was downright painful to drive, even the slightest hint of load and the clutch went south.
Next on the cards is a new set of tyres and/or wheels, plus fixing the radiator and diff leaks that they found when it was up on the hoist.
I hope family car = Aristo with 2JZGTE.... :wink:
Personally I'd prefer Chaser with manual VVTi 1JZ, it'd take a lot of convincing for me to buy an auto anything, especially not when I have the option of a manual :P
