Delete
  • Replies 74
  • Views 45.3k
Nice Terry :P
If you want another then email Trev and see if he has his floating around still, I thought this was his one but the owners said that they have owned it for numerous years, Trev was chasing 200 - 300 for his when he was trying to flog it off to me.
[email protected]
terry if you want a fibreglass roof I have a good contact, well the best, our fibreglass guy at work does very good work and does cashies...
pm me if you want me to hit him up.
so went and picked it up tonight
Interesting.
I spy a 5 stud front end conversion...
this will be 5 stud alround, i have 3 full sets of wide Jap rims waiting for it here
also has a factory ELECTRIC roof
towed it home roof down, cause i can :laff:
roof is 18mth old and in perfect nick , also has a full cover similar to mgb style
and the roof down cover fitted in pics
ex owner paid $800 for that stuff :yes:
Edited by mungi mods
ssr reverse mesh
16 x9 /16 x 9.5
work ewing mesh
15 x 9.5/ 15 x10
also a set of Volk GT-Cs in 16 x 9/16 x 10
oh man this thing will be cool.
Pity it's a 60 not a 65, 65 front ends are cooler.
Will be ra65 or ga61 front
pics with other cover fitted
so today i have removed all the bump strips, tailights and rear garnish, rear bar and towbar
all boot lining and wiring in readiness for rust removal and plating and weld filling all unnessecary holes
this thing has soo much bracing and strengthening in . the rear has a 50 x 25 boxed crossbrace into the rear inner arch which are reinforced with 4mm plate
cabin side of boot floor is also reinforced with 4mm plate and 50 x 25 box section
b pillar is reinforced as well with 4mm angle which has sections going rearward to the crossbracing as well.
will post some pics soon
oh also it is now a runner, the stock 21rc is healthy as is the stock w57 with short shifter
clutch seems good too, factory fitted t series isok as well.
plan is fix , paint,rego then will start the 1jz conversion
Heres that Photoshop work you were after in another thread, kinda more applicable here:
Before:
After:
yup w57 off compliance plates
t series diff = T-312 3.9-1 ratio
progess
Thanks to Matt (Littleredspirit) for letting me use his huge awesome shed to work on this
so i have removed the towbar/rear bar which were welded together ,and are now binned
removed all bumpstrips and badging as i am welding up the holes and associated rust.
removed boot, tail lights and all rear garnishes to perform rust repairs.
boot had a lot of rust which has now been plated with new steel.
car now runs perfectly but still need to source a new fuseable link for it as the original was corroded and f*#ked
Everything except the wipers works , but i think the wiper motor has sh*t itself so will get another from the wreckers
Trying to find a rear bar atm to suit, not sure if hatch rear bar is the same .
should have all rust repairs finished by the end of the week hopefully then i will be going for
rego before theserious modification begins
Tossing up whether i should step up to 17 inch rims atm, rather than 15's either way i want 100mm ground clearance and full flush with tuck
I think i am going to keep it white but am not sure ye
will have to take some pics and post em up when and if i remember
It really needs a name
maybe
_____ the convertible or _ _ _ _ the droptop
