The Off-Topic Thread
  • Replies 1.4k
  • Views 394.1k
  • You don't have to know it all, that's what the training is for. Know-it-alls are usually smartasses who don't actually know much at all, so they don't get hired. I think you're better off not being on
  • Just bought my son a bottle of 18yo chivas regal, gave it to him and he didnt care but i guess its because he turnned one today and has no idea what it is haha. Ill be sharing it with him on his 18th
Buy a good hammer, only time I have ever had to use a pitman arm puller was to, well, remove a pitman arm. Give the steering arm a whack on the edge around the joint (with the nut loosened off) and it should pop out.
Oh sorry man, I didn't realise you were actually changing the ball joints aswell, they will be a press in.
I haven't actually changed an E7 ball joint but every other was press out and in in the hydraulic press.
All I remember from doing my struts was undoing the 2 lower strut bolts, removing the ball joint nut and then the tie rod end nut and changing the arms over and then the struts.
Hmm, maybe it'd be cheaper to get it all out and get a mechanic to press them in. Those tools aint cheap.
Theres actually a hydraulic press at my course, might use that on Wednesday.
Edited by B.L.Z.BUB
I machined myself a separator fork for doing tie rod ends. Hardened spring steel etc. Was popping 30+yo tie rod ends with 1 belt.
Worked much easier than the puller I have. Then again, the Sykes Pickavant puller set is WAY overkill for Corolla tie rod ends haha.
Reed: Get the suspension joint to remove the ball joints. Not too hard, but if your paying for them to be installed, might as well get them to pull em out too.
Edited by SLO-030
Hammer works good enough.. As long as you hit straight, if you bend nails then forget it.. You can rig a G clamp to work pretty well.
For steering arms and tie rod ends hammer works well, just smack it on the side and it'll wiggle loose.
