November 6, 201114 yr comment_564640 Hey what recommendations for a brake fluid for a race application? We are now running Wilwood fronts with AE192 rears Edited November 6, 201114 yr by Rob 5000 Report
November 7, 201114 yr comment_564802 ARRANGED BY DRY BOILING POINT: DRY:401F -- WET:284F --- DOT3 MINIMUM (GLYCOL BASE) DRY:446F -- WET:311F --- DOT4 MINIMUM (GLYCOL BASE) DRY:500F -- WET:356F --- DOT5 MINIMUM (SILICONE BASE) DRY:500F -- WET:356F --- DOT5.1 MINIMUM (GLYCOL BASE) DRY:500F -- WET:???F --- FORD HEAVY DUTY DOT 3 PM-1C (new since 2006) DRY:527F -- WET:302F --- AP RACING 551 ($12.95/0.5L OR 16.9 OZ) DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4 DRY:536F -- WET:388F --- ATE SUPERBLUE/TYP200 ($9.95/1L) DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 PM-1 (pre 2006) ($4/12 OZ) DRY:570F -- WET:284F --- WILWOOD 570 ($5.65/12 OZ) DRY:570F -- WET:284F --- PERFORMANCE Friction Z rated ($6.27/16 OZ) DRY:572F -- WET:410F --- AP RACING 600 ($16.95/0.5L OR 16.9 OZ) DRY:590F -- WET:518F --- CASTROL SRF ($69.00/1L 0R 33.8 OZ) DRY:593F -- WET:421F --- MOTUL RBF600 ($12.95/0.5L OR 16.9 OZ) DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS ($26.75/0.5L OR 16.9 OZ) DRY:608F -- WET:390F --- AP RACING 660 ($28.99/0.5L OR 16.9 OZ) DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610 ($11.95/12 OZ) DRY:626F -- WET:417F --- QUADRIGA/PROSPEED GS610 ($14.99/16 OZ) DRY:626F -- WET:417F --- WILWOOD EXP 600 ($16.95/0.5L 16.9 OZ) DRY:635F -- WET:430F --- PROJECT MU G/FOUR 335 ($45.00/1.0L 33.8 OZ) wet boiling point is fairly important as well, apparently that temperature is measured when there is 3.7% water in the system. so id go with a fluid that suits your brake system, and is as close to the bottom of that list as possible. the prices are most likely out dated, was a pretty old post...but i coudlnt be bothered reseaching each fluid and getting updated specs.... Report
November 24, 201114 yr comment_567945 pbr600 order it from bursons say you want the stuff hayden uses in the supercar Report
November 24, 201114 yr comment_568012 Best thing is to change it often, Yeah Motul 5.1 or RBF600 have good temps, aren't too expensive and also available locally that I have found so far. Whatever you do don't use DOT 5 silicone stuff (DOT 5.1 is std gylcol base.) Report
November 24, 201114 yr comment_568017 Find some penrite synthetic brake fluid, good temp rating and its not silicone based, and cheap to Report
November 24, 201114 yr comment_568024 Ducting... get the heat out before it builds up. you need a proper brake duct that blows into the hub its hard to explain i'll show you when i have a look at the 82 Report
November 24, 201114 yr comment_568031 i just bought a bottle of the penrite sin stuff...along with a set of QFM brake pads. will be interesting to see how it goes. brake fade on the wrx is insane... Report
November 25, 201114 yr comment_568035 i just bought a bottle of the penrite sin stuff...along with a set of QFM brake pads. will be interesting to see how it goes. brake fade on the wrx is insane... I've got Green Stuff in mine. I left foot brake like a bitch too so we'll see how they stand up. I've used QFM's before and they're not bad. Edited November 25, 201114 yr by Redwarf Report
November 25, 201114 yr comment_568053 yeah i had the QFX on the front of the corolla, was very happy with them, so ill give them a go on the rexy. not bad for 80bucks/end too. Report
