February 3, 201214 yr Author comment_582023 So I just got my tax money in today BAM! I want to start ordering parts for this block but not really sure on what engine i need to be ordering for. If I order parts for a 4AGE will it still work on this engine. How can i tell what kind of engine it is with the engine number? The guy told me it was from a MR2 so my question is the MR2 engine and the GTS corolla engine the same Report
February 3, 201214 yr comment_582045 That's a first gen bigport head. If your really motivated change the valve stem seals and port the head while your at it. Otherwise they arn't known to have any issues. Report
February 4, 201214 yr Author comment_582207 I wanted to know what can i use to clean the exhaust valves on the head they look pretty dirty. Also the block its full of dirt and old oil. I was thinking carburetor cleaner or brake cleaner. Not sure i just don't want to put anything on it and mess things up. Report
February 5, 201214 yr Author comment_582293 Looking at this engine rebuild kit let me know what you think. http://www.ebay.com/itm/1985-1987-Toyota-Car-1587-1-6L-DOHC-L4-16V-4AGE-ENGINE-REBUILD-KIT-/270840884018?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3f0f5feb32 Edited February 6, 201214 yr by Alvarado.e09 Report
February 7, 201214 yr Author comment_582981 The Mechanic that is going to rebuild my engine said I need a bolt kit. I'm not sure if i need to replace all bolts or just the Main Stud Kit Head Stud Kit Rod Bolt Kit? Little Help Please. Also is there a place to get these cheep? Report
February 7, 201214 yr Author comment_583003 He just said i need a bolt kit because the old bolts can only be torqued once. So my question is what bolts should i replace and what can i reuse to save some cash. Report
February 10, 201214 yr Author comment_583703 Alright I talked to the mechanic and he told me i just need Head Bolts. I was looking at these on ebay http://www.ebay.com/itm/Cylinder-Head-Bolt-Set-4AF-4AFE-4AGE-4AGEC-4AGELC-4AGZE-/160442543388?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item255b1eed1c Report
February 10, 201214 yr Author comment_583704 Sam told me i should replace the Valve Steam Seals on the head. http://www.ebay.com/itm/Supertech-Viton-Valve-Stem-Seals-Toyota-4AGE-16v-AE86-Corolla-1-6L-/260917612104?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3cbfe6ce48 I think the only thing i am missing is the water pump but not sure? Report
February 10, 201214 yr comment_583714 He just said i need a bolt kit because the old bolts can only be torqued once. So my question is what bolts should i replace and what can i reuse to save some cash. your mechanic is full of shit, on some engines this is the case (torque to yeild bolts) but not on Toyota's. They determine the reusability of a bolt by checking the stretch. When they have too much stretch they get too thin and have to be replaced. This is right in the service manual if he doesn't want to listen to some random on the internet. I would trust Toyota bolts that have been used a few times over those non new non-genuine bolts that are probably chinese. Also if you buy a gasket set they should come with valve stems. Edited February 10, 201214 yr by Sam_Q Report
February 10, 201214 yr Author comment_583722 Alright thanks for the info Sam Ill just reuse my head bolts if you say its okay. The rebuild kit I'm getting has a gasket kit Ill send them a message and see if it comes with valve stem seals. http://www.ebay.com/itm/1985-1987-Toyota-Car-1587-1-6L-DOHC-L4-16V-4AGE-ENGINE-REBUILD-KIT-/270840884018?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3f0f5feb32 Report
February 10, 201214 yr comment_583724 do you have a proper workshop manual? if so you yourself can check the diamter and see if they reusable. Report
February 11, 201214 yr comment_583727 I'm the kind of guy who replaces most things while the engine is out of the car. The price of a set of new headbolts to be sure isn't much if it guarantees longevity of the motor and means i won't have to touch it again for a while. Mind you I'm doing a 5k which is probably a bit older than your 4age but my headbolts are shagged Report
February 14, 201214 yr Author comment_584463 Okay so after all of this engine talk i found a running engine for 795 shipped. I'm not sure if i should rebuild or buy that engine. I was told it has 100k on it but it is running with warranty. I'm a little suck and not sure on what i should do. Any suggestions. Report
February 14, 201214 yr comment_584473 It will cost you significantly more to rebuild an engine, I say buy it Report
