Corona Lcs'S
hey fellaz.
ok i have my tx130 corona lca's and bran new rubbers for em too. BUTT!!! they look like they are really really long. as in to long for the controle arm? I'm 99,4% they are the right rubbers. does this sort of problem sound familar to anyone??
oh and i now haveing new ones. the ones i got with it "thinking they were the wrong ones" baught another set and got....
the same ones.
(thanks zac)
>< so i know they are right but they just don't seem like they fit! I'm tryin to get some pics up but it is freakin right now and wont let me haha
so i have two sets of rubbers. if some one is in need hit me up haha pro bushers or somesh#t i forget.
Tryed pressing them in?
What exactly is the problem mate? Kinda hard to tell, is it the lca bushes that are the problem or the arms themselves? And what are they going into? cbf searching for threads atm.
So are the bushes too long? If so how much? Is the circumfrance right?
Edited by ae824ate
Heath, press "use full editor" at the bottom under this "fast reply" screen and it will load the photo using that. "click to attach files" button.
Edited by altezzaclub
maybe you can see the problem now haha sorry guys.
and it is the rubber that is the problem they just don't seem right?
the bush comes with a crush tube, without it is useless, i would say you have the wrong part, when i ordered my superpro bushes, the crush tube and urethane was moulded as one
yeah wrong bush, take it back.
you want this:
http://www.superpro.com.au/find-superpro-parts-for-my-vehicle/part?id=SPF0509K
that thing sais "use original shell"
not sure what that means.
but it comes with 2x bushings and 2x inner tubes.
you don't appear to have the inner tubes.
also it should be VERY tight, like....need a press to get it in and out tight.
It means you need to use an oxy torch to melt the old rubber out of the metal shell some fulcrum bushes are like that it's kinda gay but they are a good product .. If u don't have the old shell u could go and buy a nolathane or white line bush and I may have a shell as well
ok! sorry.
i do have the inner tube i just didnt put them in for the pic... they just slot in
BUT!! the guy i got the arms off came round today, and he couldnt even work out the hell is up. does any one have a picture of coron LCA's they can put up? cause it is starting to look like they are the wrong arms!@!E@!#
ohh and i checked that link. they are 1204214% the same. i got a mate who is a sales rep to get them for me. so i know they are the right ones hahaha
Did you read my post above you need the outer metal shell from the original bush that was is the arm and you press the super pro bush into it after u remove the old rubber with an oxy torch
oh sorry man i didnt see it hahaha but humm alirght...
the thing is i baught these for my car from a mate. when i got these they didnt have any sort of outa shell with, can i just use the ke70 one i will have to pull out to put the corona ones in?
As I understand it, you don't need an outer shell with two-piece bushes like Nolathanes.
The originals were one-piece, consisting of an inner steel tube, an outer steel tube and 'Metalastic" rubber injected molten in between them, so the rubber has to distort to let the suspension go up and down. The outer tube was a press-fit (with a hydraulic press or a vice) into the LCA, the inner tube gripped by the bolt.
The Nolathane bushes I've worked with are just pushed into the LCA, usually just a smack with a hammer does it. I think the inner steel tube rotates inside the plastic when the suspension moves up & down.
Does that agree with what other people have seen??
Heath, have you got the right bushes that fit neatly??
