It's_AUDM_Yo Posted April 19, 2012 Report Posted April 19, 2012 (edited) How I got the car Chucked wheels and bumpers on. How it is now Parts List Engine: AE92 small-port 4A-GE Cut 'n' shut intake manifold TRD copy extractors Mandrel bent 2.5'' with sports muffler and high flow CAT Egay catch can Cusco Strut brace Fuel System: 1L Surge tank Bosch BFP070 main pump Goss GE015 lift pump Drivetrain: T50 TLS short shifter Unknown clutch AE71 driveshaft Suspension/Brakes: Front= RA65 Struts RA65 Brakes RA65 Power steering arms KE55 Low control arms HSD Coil-over kit 8kg Springs KYB Excel-G's from SW20 MR2 Rear= Lowered springs KYB 343113 shocks Interior: Personal Neo Grinta OBX Daytona 2'' SAAS oil pressure gauge 2'' SAAS water temp gauge Exterior Egay mirrors Kamei Lip Louvre Wheels: Enkei Mesh 14x6 +8 Watanabes 14x7 +10 T18 stocko's *WILL UPDATE AS I GO* If anyone wants details or photos of anything just let me know, I'm happy to answer. Edited December 12, 2012 by It's_AUDM_Yo Quote
glenpos Posted April 19, 2012 Report Posted April 19, 2012 looks awesome, should be fun when its done :y: me like :D Quote
It's_AUDM_Yo Posted April 19, 2012 Author Report Posted April 19, 2012 looks awesome, should be fun when its done :y: me like :D Thats the plan keep it fun keep it cheap.....ish Also getting some 14x6 +8 Enkei Mesh's from Otomoto on Monday! Quote
glenpos Posted April 19, 2012 Report Posted April 19, 2012 Thats the plan keep it fun keep it cheap.....ish Also getting some 14x6 +8 Enkei Mesh's from Otomoto on Monday! cool, yeah cheap is good :y: Quote
It's_AUDM_Yo Posted April 24, 2012 Author Report Posted April 24, 2012 Wheels arrived from Otomoto can't recommend them enough. Let the cleaning begin. Quote
It's_AUDM_Yo Posted May 5, 2012 Author Report Posted May 5, 2012 (edited) Swapped the rear springs and wheels today pretty happy with how it looks. Started to do the front end should have it all basically done by the end of the weekend. Edited May 5, 2012 by It's_AUDM_Yo Quote
rian Posted May 5, 2012 Report Posted May 5, 2012 Wheels look good. It's refreshing to see someone running a normal wheel and tyre size for once and not opting for the 'stretch' look. Good work. Quote
B.L.Z.BUB Posted May 5, 2012 Report Posted May 5, 2012 ^that. flog the 4k-c until it expoldes into a big fireball So you'll never do the 4age then :lolcry: they never die! Quote
It's_AUDM_Yo Posted May 5, 2012 Author Report Posted May 5, 2012 (edited) Yeah its a track focused car so I'd rather have grip/handling than repz on ThE InTeRnEt. The narrower wheels will keep the weight down as well as its gunna be used for predominately for drift. The 4k-c didn't start this morning :hmm: It seems to be turning over slower and kinda popped once or twice? any common culprits? Edited June 19, 2012 by It's_AUDM_Yo Quote
It's_AUDM_Yo Posted May 6, 2012 Author Report Posted May 6, 2012 I've used a jumpstart every time i've ever started the car so I can't imagine its that. Its actually got me buggered it started fine the other day. Quote
kickn5k Posted May 6, 2012 Report Posted May 6, 2012 I've used a jumpstart every time i've ever started the car so I can't imagine its that. Its actually got me buggered it started fine the other day. I'm still thinking it's a dud battery. But also the starter motor might be on it's way out. Could be pulling too much power. Quote
LittleRedSpirit Posted May 6, 2012 Report Posted May 6, 2012 Check all your ground cables, they should be really tight and touching bare metal. It can help a lot to just remove them, clean where they contact and then do them back up. Quote
